Cesarman Posted May 23, 2013 Posted May 23, 2013 I'm new to this forum, and I'm glad I found it. I am also new at lisp, although I have programming experience with other languages. My question is how come a lisp routine won't work on my mac?. First thing that I wonder is the c: right after the defun. Can someone point me to some good article on this? Thanks! Quote
ReMark Posted May 23, 2013 Posted May 23, 2013 There are many features that are missing. See for yourself.... http://www.blog.cadnauseam.com/2012/07/30/autocad-2013-for-mac-the-holes-live-on/ You have my sincere condolences. Quote
troggarf Posted May 23, 2013 Posted May 23, 2013 I dont have an article to reference yet, but I know that ACAD for MAC can run pure AutoLISP but not Visual LISP like "VL" "VLA" "VLAX"... Quote
ReMark Posted May 23, 2013 Posted May 23, 2013 From JTB World... Most AutoLISP will work unless it includes Windows calls (using .NET) or uses DCL dialogs Most ARX applications will work unless it includes MFC or .NET calls Quote
Cesarman Posted May 23, 2013 Author Posted May 23, 2013 ReMark said: There are many features that are missing. See for yourself.... http://www.blog.cadnauseam.com/2012/07/30/autocad-2013-for-mac-the-holes-live-on/ You have my sincere condolences. Well, thanks I will start reading Quote
Cesarman Posted May 23, 2013 Author Posted May 23, 2013 Thanks! I appreciate any sort of advice! Quote
ReMark Posted May 23, 2013 Posted May 23, 2013 You should change your profile to read AutoCAD for Mac 2013 so we'll know you aren't playing with a full deck. Luke....come over to the Dark side. Quote
neophoible Posted May 23, 2013 Posted May 23, 2013 Cesarman said: I'm new to this forum, and I'm glad I found it. I am also new at lisp, although I have programming experience with other languages. My question is how come a lisp routine won't work on my mac?. First thing that I wonder is the c: right after the defun. Can someone point me to some good article on this? Thanks! Welcome to the forum. There may not be many if any Mac users here, but there still may be some help with routines. They may have to be "dumbed down" to work, but in many cases that may not be too hard, or there may already be an alternative version that would work. To start out, you will probably want to just post whatever routine won't work and learn from there. Lots of folks here are happy to explain things. The C: right after the defun means you can type the name (minus the "C:") right on the command line as though it is an AutoCAD command, that is, with no parentheses. Quote
neophoible Posted May 23, 2013 Posted May 23, 2013 ReMark said: You have my sincere condolences. Mine, too, especially, if you were "forced" into it. troggarf said: I dont have an article to reference yet, but I know that ACAD for MAC can run pure AutoLISP but not Visual LISP like "VL" "VLA" "VLAX"...Mentioned in ReMark's link. Cesarman said: Thanks! I appreciate any sort of advice! ReMark said: You should change your profile to read AutoCAD for Mac 2013 so we'll know you aren't playing with a full deck. Yes, good advice. And you might mention it in your posts, just in case folks miss it otherwise. ReMark said: Luke....come over to the Dark side.This may be the best advice! Quote
Cesarman Posted June 4, 2013 Author Posted June 4, 2013 neophoible said: Welcome to the forum. There may not be many if any Mac users here, but there still may be some help with routines. They may have to be "dumbed down" to work, but in many cases that may not be too hard, or there may already be an alternative version that would work. To start out, you will probably want to just post whatever routine won't work and learn from there. Lots of folks here are happy to explain things. The C: right after the defun means you can type the name (minus the "C:") right on the command line as though it is an AutoCAD command, that is, with no parentheses. I will follow your recommendation, thanks a lot Quote
