remizana Posted May 23, 2013 Posted May 23, 2013 hi my problem is when I create a camera in my scene only the cone appears and there is no shape of a camera and its target there. of course it's not on a hidden layer or the "shift+c" .how can I fix it????? Quote
Cad64 Posted May 23, 2013 Posted May 23, 2013 Go to the Customize Menu > Preferences > Viewports Tab and check the setting for Non-Scaling object size. If the setting is 0.0, change it to 1.0 and see if that fixes the problem. Quote
remizana Posted May 23, 2013 Author Posted May 23, 2013 :lol:thank you so much, thank you so much, thank you so much, Quote
Cad64 Posted May 23, 2013 Posted May 23, 2013 I take it the problem is solved? You're very welcome. Quote
remizana Posted May 23, 2013 Author Posted May 23, 2013 thanks "Cad64". yes the problem solved. Quote
