ReMark Posted May 25, 2013 Posted May 25, 2013 Switch to an isometric view then insert your transformer. Use your Osnaps to place it accurately. I'd suggest using a 2Dwireframe visual style during placement then switch to a shaded or conceptual visual style to see if you truly got the placement correct. Quote
kulfi Posted May 26, 2013 Author Posted May 26, 2013 I am not talking about AutoCAD this issue is for AutoCAD Utility Design Software. thanks Quote
ReMark Posted May 26, 2013 Posted May 26, 2013 You would benefit from some customized training. http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2772547&linkID=9242856 If that isn't an option maybe you should stop using AUD and switch over to plain AutoCAD. Quote
kulfi Posted May 26, 2013 Author Posted May 26, 2013 All BIM are Vertical Products than why i can not switch to 3d views. thanks Quote
ReMark Posted May 26, 2013 Posted May 26, 2013 I don't see why you would be having trouble switching to a 3D view of any kind. Are you using the Ribbon? Are you working in a 3D workspace? Quote
kulfi Posted May 27, 2013 Author Posted May 27, 2013 Let me explain little when i am working in BIM softwares from IDS 2013 or BDS 2013 why i can not get my 3d models Quote
Murph_map Posted May 27, 2013 Posted May 27, 2013 Are you using MEP or just AUD? Two different packages for two different industries. Quote
kulfi Posted May 27, 2013 Author Posted May 27, 2013 I want to use AUD 2013 and show my underground Electrical Utilities. thanks Quote
Murph_map Posted May 27, 2013 Posted May 27, 2013 I want to use AUD 2013 and show my underground Electrical Utilities.thanks It's been 5 years or better since I used AUD or what used to be Gen-Map. Back then it was only a 2d application used to help design the elertical system overhead and underground sizing the conductor and transforms for the user. If it now has 3D and does show profiles then I know nothing about it. You need to call your reseller that you bought it from. Quote
kulfi Posted May 27, 2013 Author Posted May 27, 2013 I am very Happy that at least you are answering my queries i wanted to tell you that we have reach our re seller here and than Europe and USA still no solution i am wondering that why the software is there and i can not find the trainer. thanks Quote
ReMark Posted May 29, 2013 Posted May 29, 2013 Maybe this is why you can't find an answer. Seems there is something missing in the 2013 version. Quote
anniesmith Posted June 28, 2015 Posted June 28, 2015 To Orbit the View of a 3D Object:- Select one or more objects that you want to view with 3DORBIT or select no objects if you want to view the entire drawing. Note: OLE objects and raster objects do not appear in the 3D Orbit view. Click View tab Navigate panel Orbit drop-down Orbit. Use one of the following methods to orbit around the objects: To rotate along the XY plane, click in the drawing and drag the cursor left or right. To rotate along the Z axis, click in the drawing and drag the cursor up or down. To allow unconstrained orbiting along the XY plane and the Z axis, press Shift while you drag the cursor. An arcball is displayed and you can use the 3D Free Orbit interaction. Sincerely, SD- Academy Quote
