dbroada Posted May 16, 2013 Posted May 16, 2013 (edited) We currently have a mixture of AutoCADs in the office. We all had ACAD2011 on XP but there are now 2 machines with ACAD2013 on XP and one ACAD2013 on 64 bit Win7. I am in the process of changing my VBA routines to VB.Net but naturally, the main one is still only working in VBA. And this is where the problem comes. The boss' machine (the 64 bit Win 7) doesn't like the line.. Dim PlineObj As AcadLWPolyline It says it doesn't know what an AcadLWPolyline is, where my machine is quite happy. Can anybody shed some light on how to coax the newest installation into running my code? The rest of the office are due to move on to ACAD2013/Win7 and it would be nice to get it working before too long. I'm not sure when I will be moved but currently I am probably going to be last. ==================== the message I get is "Object or library not found", but the references look the same - he is a long way from me and I keep forgetting by the time I walk from one machine to the other. Edited May 16, 2013 by dbroada more info given Quote
Tyke Posted May 16, 2013 Posted May 16, 2013 I have several VBA Macros that use LW polylines and they work on all versions of AutoCAD from 2002 to 2013 XP to W7, 32 and 64 bit. We have a single machine that is 64 bit W7 running AutoCAD 2013 and that causes problems sometimes. It automatically adds a reference to the "AutoCAD 2013 Type Library" to the macro. In itself tjat is not a problem, but as our macros are located on the server and not locally on each machine it means no one else can use the macros any more. My solution was for the one machine to have the macros saved locally on the machine and not let it access the macros on the server and we have had no problems since then. Try adding a reference und Tools > References to "AutoCAD 2013 Type Library" and see if that works. You will have to do that on his machine. Quote
dbroada Posted May 16, 2013 Author Posted May 16, 2013 the "AutoCAD 2013 Type Library" is referenced on his machine,as it is on mine. They both appear to be loaded from C:\Program Files\Common Files\Autodesk Shared\acax.19enu [something that disappears off the side of the box but is probably .tlb]. However, I have just noticed that the VBA project is not saved on either C: drive. I don't know how that happened as I normally give each machine it own acad.dvb file. I'll try saving the dvb locally again and see what happens. Quote
BlackBox Posted May 17, 2013 Posted May 17, 2013 When you added the Library (assembly) reference to your VB.NET project, did you make sure to set Copy Local = False? Quote
dbroada Posted May 17, 2013 Author Posted May 17, 2013 When you added the Library (assembly) reference to your VB.NET project, did you make sure to set Copy Local = False?I think so. This problem is with a VBA project but there will be my VB.Net project already running. Will they influence each other? Quote
BlackBox Posted May 17, 2013 Posted May 17, 2013 I think so. This problem is with a VBA project but there will be my VB.Net project already running. Will they influence each other? My mistake, Dave... I incorrectly thought this was about .NET, and not VBA (I've been sick for days, and am forcing myself to work today to keep my word about getting a submittal out... It appears that I left my wit at home)... In any event, if VBA's anything like .NET it should be fine, as the code only needs to Interface with the Objects, Modules, etc., but again, I am no VBA guy. I defer to whatever Tyke says. Quote
dbroada Posted May 17, 2013 Author Posted May 17, 2013 I think this is going to be "one of those things". I don't get time to check these things out sensibly and just have to try sticky tape to keep it running. The second Win 7/Acad2013 has just arrived in the office so we can see whether that one plays nicely or not. Quote
BlackBox Posted May 17, 2013 Posted May 17, 2013 A dumb man doesn't know how smart he is; a smart man knows how smart he isn't. Quote
Tyke Posted May 18, 2013 Posted May 18, 2013 A dumb man doesn't know how smart he is; a smart man knows how smart he isn't. And which category are you placing me in? It would be best if you didn't answer that one Quote
dbroada Posted May 20, 2013 Author Posted May 20, 2013 I have several VBA Macros that use LW polylines and they work on all versions of AutoCAD from 2002 to 2013 XP to W7, 32 and 64 bit. We have a single machine that is 64 bit W7 running AutoCAD 2013 and that causes problems sometimes. It automatically adds a reference to the "AutoCAD 2013 Type Library" to the macro. In itself tjat is not a problem, but as our macros are located on the server and not locally on each machine it means no one else can use the macros any more. My solution was for the one machine to have the macros saved locally on the machine and not let it access the macros on the server and we have had no problems since then. Try adding a reference und Tools > References to "AutoCAD 2013 Type Library" and see if that works. You will have to do that on his machine. our second installation with Win 7 happened today, and it doesn't work there either. It is our subbie's machine and she is not working Wednesday so I can get on the machine and look more closeley then. Saving the DVB locally hasn't made any difference. Where does your Win7 one add the reference? Quote
Tyke Posted May 21, 2013 Posted May 21, 2013 our second installation with Win 7 happened today, and it doesn't work there either. It is our subbie's machine and she is not working Wednesday so I can get on the machine and look more closeley then. Saving the DVB locally hasn't made any difference. Where does your Win7 one add the reference? If you open the VBA Manager, load the project and then open the VBAIDE and the project. When you are in one of the modules got to the menu Tools > References and a window will appear. When I look in there the last item that is ticked is the 'AuoCAD 2013 Type Library'. If it does not appear, scroll down the list until you find it and then tick it. Under the ticked items at the top all other items are ordered alphabetically, so its easy enough to find. AutoCAD 2012 does it too on W7 the machines here, okay 2012 is not an issue with you Dave, just for completeness. Also on "011 and earlier the W7 machines don't add their type libraries! Strange! What happens if you 'step through' the macro instead of running it? Best of luck with it, it looks like you are in for an interesting day. Quote
dbroada Posted May 21, 2013 Author Posted May 21, 2013 What happens if you 'step through' the macro instead of running it? I have probably declared this wrong but it used to work... In the declarations area i have Dim PlineObj As AcadLWPolyline and this is where it the problem occurs. I can't step through as it falls over on the very first line. If I comment out that line it falls over as the first line that calls PlineObj. This is my screen shot but I did check that machine 1 was the same. I will check the other tomorrow. Quote
Tyke Posted May 21, 2013 Posted May 21, 2013 I don't know if this will cause problems elsewhere with the rest of your code but have you tried declaring your polyline object so: Dim PlineObj As AcadPolyline This would then be a 2D ployline which carries a bigger overhead than a LW polyline, but it could work. Declaring a LW polyline on my W7 machines is not a problem and the only differences I can see between my machines and yours is that mine run a German OS and a German version of AutoCAD whereas yours are English. But I can't imagine that should make any difference. B Quote
dbroada Posted May 21, 2013 Author Posted May 21, 2013 OK, thanks Tyke - I will look tomorrow on Jo's machine. I could well be on here quite a bit! I will try that on mine now and see what happens but I'm off to a recording of QI this afternoon so won't spend too long on it. Quote
Tyke Posted May 21, 2013 Posted May 21, 2013 I'm off to a recording of QI this afternoon I know that I should not perhaps ask this, but what is QI? Quote
dbroada Posted May 21, 2013 Author Posted May 21, 2013 a British TV show that you must be sadly missing in Germany. Hosted by Stephen Fry with two teams "interesting" people. Somewhere between a chat show and a comedy quiz show - sort of "Have I got news for you" (if you have seen that) - which coincidentally I am off to see a recording of on Thursady. Anyway, I looked at changing the polyline but there were too many minor changes necessary that I couldn't get very far without spending much time on it. I will print out the code before I try again! One of the problems was my original code was sloppy and the "On error resume next" line was masking all sorts of problems. Quote
Tyke Posted May 21, 2013 Posted May 21, 2013 Nope, QI is something that I haven't seen and that we don't get here in Germany, but I will have a look and see if I can see it on my iPad. But on the other hand, Strphen Fry and "Have I got news for you" are a couple of my favorites. Have a good time and give my regards to Heather. Quote
dbroada Posted May 22, 2013 Author Posted May 22, 2013 Good morning Tyke, guess what? I got on Jo's machine this morning, commented out a couple of "on error resume next" lines and the routine fell over where I was trying to add a UCS component. I commented them out, uncommented the "On Error" lines and it looks like it is now behaving. Just have to check that mine is the same.... Jo's machine and the boss' machine work today. If they don't work tomorrow hopefully it is just a matter of finding the right folder to put the DVB file in. Quote
