Mr Wiggle's Giggles Posted May 15, 2013 Share Posted May 15, 2013 (edited) Is there any way to pull text from a spreadsheet into arc-aligned text? Like if I were trying to make round inspection tags but didn't want to type in the inspection code each time, or if I needed to change something? Is it possible to put a field into the text to refer to a cell location in Excel? About me: I just started using AutoCAD 2011 (I was previously using AutoCAD 2005) and am having a hard time finding my old controls while learning all the new features for which I got the program. Please use small words. Edited May 16, 2013 by Mr Wiggle's Giggles Quote Link to comment Share on other sites More sharing options...
Mr Wiggle's Giggles Posted May 16, 2013 Author Share Posted May 16, 2013 UPDATE: So I found this third-party script called XL at http://www.jefferypsanders.com/autolisp_XL.html. The way I read the description, it won't do quite everything that I want, but it will at least pull text from Excel into AutoCAD, so that's a step in the right direction. Or rather, it might if I could get it to work. The install instructions say to load it into the search path, which I have done, but the command line to execute (which is supposed to be just "XL") runs 'xline,' which tells me that it hasn't been properly added. What I have done is basically extract the script into the support folder and added it in the support file search path. Evidently I need to do something else before I can initialize it. Also, once I get that working, there is still the issue of getting a field into arc-aligned text, which I have been unable to accomplish as of yet. Quote Link to comment Share on other sites More sharing options...
Mr Wiggle's Giggles Posted May 21, 2013 Author Share Posted May 21, 2013 Since no one responded to this post, I guess that means it cannot be done? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 21, 2013 Share Posted May 21, 2013 The program does work as described by Mr. Sanders. I just tested it myself. I am running AutoCAD 2013 and MS Office 2003. I used the XL_Test.xls file included in the zip file. The program does not seem to work on arc-aligned text. It also does not appear to work on MText only DText. Quote Link to comment Share on other sites More sharing options...
Mr Wiggle's Giggles Posted May 21, 2013 Author Share Posted May 21, 2013 Would it be a valid workaround to use XL to call the text to some obscure corner of the drawing and then use a field to get it to where I want? I don't have a whole lot of experience with fields, so I'm not certain whether that would work or not. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 21, 2013 Share Posted May 21, 2013 Sounds convoluted to me. I can't tell you if that would work or not though. Quote Link to comment Share on other sites More sharing options...
