teknomatika Posted May 15, 2013 Share Posted May 15, 2013 Why "too few arguments"? (defun c:mci (cp) (setq cp (getpoint "\nCenter point:")) (entmake (list (cons 0 "CIRCLE");;Entity (cons 62 5);;Color (cons 10 cp);;Center point (cons 40 2);;Radius ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 15, 2013 Share Posted May 15, 2013 (defun c:mci ([color=blue][b]/[/b][/color] cp) Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted May 15, 2013 Share Posted May 15, 2013 You defined function as it requires argument (cp) and c:mci is defined as command function so you can't supply that argument, for as soon as you execute it in standard way like any other command with Command: mci, no argument is passed to function... So change line (defun c:mci (cp) to (defun c:mci ( / cp ) as like you've written later in function parameter cp is variable user supplies while function runs... So cp isn't argument but variable that needs to be localized... Quote Link to comment Share on other sites More sharing options...
MSasu Posted May 15, 2013 Share Posted May 15, 2013 I believe you were looking to localize the variables, not to have an argument (also, not valid for commands, only for functions): (defun c:mci ( [color=red]/[/color] cp) ... Quote Link to comment Share on other sites More sharing options...
teknomatika Posted May 15, 2013 Author Share Posted May 15, 2013 Thank you both. I appreciate your explanation. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 15, 2013 Share Posted May 15, 2013 In addition to the above suggestions, you can also marginally improve the efficiency of your code by quoting expressions which need not be evaluated, e.g.: ([color=BLUE]defun[/color] c:mci ( [color=BLUE]/[/color] cp zv ) ([color=BLUE]setq[/color] zv ([color=BLUE]trans[/color] '(0.0 0.0 1.0) 1 0 [color=BLUE]t[/color])) [color=GREEN];; WCS Extrusion vector of UCS plane[/color] ([color=BLUE]if[/color] ([color=BLUE]setq[/color] cp ([color=BLUE]getpoint[/color] [color=MAROON]"\nCenter: "[/color])) [color=GREEN];; Center point in UCS[/color] ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(00 . [color=MAROON]"CIRCLE"[/color]) [color=GREEN];; Entity Type[/color] '(62 . 5) [color=GREEN];; Colour[/color] ([color=BLUE]cons[/color] 10 ([color=BLUE]trans[/color] cp 1 zv)) [color=GREEN];; Center point in OCS[/color] '(40 . 2.0) [color=GREEN];; Radius[/color] ([color=BLUE]cons[/color] 210 zv) [color=GREEN];; Extrusion Vector in WCS[/color] ) ) ) ([color=BLUE]princ[/color]) ) I have also ensured the program will perform correctly in all UCS construction planes. Quote Link to comment Share on other sites More sharing options...
teknomatika Posted May 15, 2013 Author Share Posted May 15, 2013 In addition to the above suggestions, you can also marginally improve the efficiency of your code by quoting expressions which need not be evaluated, e.g.: ([color=BLUE]defun[/color] c:mci ( [color=BLUE]/[/color] cp zv ) ([color=BLUE]setq[/color] zv ([color=BLUE]trans[/color] '(0.0 0.0 1.0) 1 0 [color=BLUE]t[/color])) [color=GREEN];; WCS Extrusion vector of UCS plane[/color] ([color=BLUE]if[/color] ([color=BLUE]setq[/color] cp ([color=BLUE]getpoint[/color] [color=MAROON]"\nCenter: "[/color])) [color=GREEN];; Center point in UCS[/color] ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(00 . [color=MAROON]"CIRCLE"[/color]) [color=GREEN];; Entity Type[/color] '(62 . 5) [color=GREEN];; Colour[/color] ([color=BLUE]cons[/color] 10 ([color=BLUE]trans[/color] cp 1 zv)) [color=GREEN];; Center point in OCS[/color] '(40 . 2.0) [color=GREEN];; Radius[/color] ([color=BLUE]cons[/color] 210 zv) [color=GREEN];; Extrusion Vector in WCS[/color] ) ) ) ([color=BLUE]princ[/color]) ) I have also ensured the program will perform correctly in all UCS construction planes. Lee, as always, efficient and master. I appreciate that. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 15, 2013 Share Posted May 15, 2013 You're very welcome teknomatika. Quote Link to comment Share on other sites More sharing options...
