hkench Posted May 14, 2013 Posted May 14, 2013 How can I draw the bottom line, with an angle of 132 relative to the middle line? Pulling my hair out here, and I don't have much to spare! Quote
MSasu Posted May 15, 2013 Posted May 15, 2013 If the top line is horizontal, then the bottom one is at 34 degrees from horizontal, so: Specify first point: Specify next point or [undo]: @50Specify next point or [undo]: @50Specify next point or [Close/Undo]: @50Just replace the length (50) with what you need. Other, just make a copy of the middle line and rotate it with -132 degrees. Quote
eldon Posted May 15, 2013 Posted May 15, 2013 When drawing relative angles, I start with the first line, then Copy it on to itself. Then Rotate about the end point using the correct + or -, then adjust the length using Lengthen. And so on, and so on. When you get into the swing of it, it goes quite fast, and there is no bothersome mental arithmetic Quote
Dadgad Posted May 15, 2013 Posted May 15, 2013 Welcome to CAdtUTOR. I too would likely do it as Eldon and Msasu suggested, with a line copied on itself. There are polar tracking options too which could be invoked. Quote
JD Mather Posted May 15, 2013 Posted May 15, 2013 I would leave the "copy on itself" step out as I am a bit lazy. I would draw the horizontal line then select it. Select the rotation point and right mouse button Rotate, right mouse button Copy and enter angle. This will create the copy at the correct angle all in one step. Repeat for second line. If the lines are not all the same length the len total can be used to set lengths. Quote
euncie Posted November 23, 2013 Posted November 23, 2013 why did you use -34?? can't understand. thanks Quote
Dana W Posted November 23, 2013 Posted November 23, 2013 why did you use -34?? can't understand. thanksAutoCad default expects angles to be counterclockwise. The '-' sign makes it go the other direction. Quote
