Print Options - AutoCAD Drawing Management & Output - AutoCAD Forums Jump to content
Hello guys,I have a problem.Need to make the dwg file into pdf but I also need to set margins(10mm top,right,bottom and 20mm on the left side),tried with some programs but it only gives me the option to set "global" margins and if i use CAD it trims the drawing.I'm working with A4(210,297).
Guest AARi
have a look here
_http://www.novapdf.com/downloads.html
open the print window: select the driver and check options margins
hope was usefull
