Lee Mac Posted May 17, 2013 Posted May 17, 2013 Thank you David, I very much appreciate your compliments. It's probably not the easiest code for a beginner to start learning from, but I admire your enthusiasm and would encourage you to pursue your learning of AutoLISP. Good luck! Quote
dortega4269 Posted May 20, 2013 Author Posted May 20, 2013 "...It's probably not the easiest code for a beginner to start learning from..." Lee Mac you were so very right, this code was not by any means easy to decipher. After reading through Afralisp for several hours and reading through your code, I now have a better understanding of what you are doing as far as creating lists and calling them up, however, trying to figure out what you are doing with each line is another story. I will enjoy and appreciate what you have provided to me and I will keep reading and gaining a better understanding of writing code. Thanks again Lee Mac:thumbsup: Quote
dortega4269 Posted May 21, 2013 Author Posted May 21, 2013 Lee Mac provided me with an awesome bit of code, but I am unsure of how to alter it. Everything is returning with an error. I have two things I'd like to see it do, but I don't know where to place any code I want to add... How would I go about making command repeat, as to, click on an object several times and have it rotate 90 degrees each time? How can I alter this code to make it rotate -90 from 0 (clockwise)? Quote
Lee Mac Posted May 21, 2013 Posted May 21, 2013 How would I go about making command repeat, as to, click on an object several times and have it rotate 90 degrees each time? How can I alter this code to make it rotate -90 from 0 (clockwise)? Try this David, ([color=BLUE]defun[/color] c:r90 ( [color=BLUE]/[/color] a e f k x ) ([color=BLUE]setq[/color] a ([color=BLUE]/[/color] [color=BLUE]pi[/color] 2.0)) [color=GREEN];; Rotation Angle[/color] ([color=BLUE]initget[/color] [color=MAROON]"X Y Z"[/color]) ([color=BLUE]if[/color] ([color=BLUE]=[/color] [color=MAROON]"Z"[/color] ([color=BLUE]setq[/color] k ([color=BLUE]getkword[/color] [color=MAROON]"\nChoose Block Rotation Axis [X/Y/Z] <X>: "[/color]))) ([color=BLUE]setq[/color] f ([color=BLUE]lambda[/color] ( l [color=BLUE]/[/color] r ) ([color=BLUE]setq[/color] r ([color=BLUE]assoc[/color] 50 l)) ([color=BLUE]entmod[/color] ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] 50 ([color=BLUE]+[/color] a ([color=BLUE]cdr[/color] r))) r l)) ) ) ([color=BLUE]setq[/color] f ([color=BLUE]lambda[/color] ( l [color=BLUE]/[/color] e r ) ([color=BLUE]setq[/color] e ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] -1 l)) r ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 50 l)) ) ([color=BLUE]vlax-invoke[/color] ([color=BLUE]vlax-ename->vla-object[/color] e) 'rotate3d ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 l)) e 0) ([color=BLUE]trans[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 l)) ([color=BLUE]if[/color] ([color=BLUE]=[/color] [color=MAROON]"Y"[/color] k) ([color=BLUE]list[/color] ([color=BLUE]-[/color] ([color=BLUE]sin[/color] r)) ([color=BLUE]cos[/color] r) 0.0) ([color=BLUE]list[/color] ([color=BLUE]cos[/color] r) ([color=BLUE]sin[/color] r) 0.0) ) ) e 0 ) a ) ) ) ) ([color=BLUE]while[/color] ([color=BLUE]progn[/color] ([color=BLUE]setvar[/color] 'errno 0) ([color=BLUE]setq[/color] e ([color=BLUE]car[/color] ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect Block <Exit>: "[/color]))) ([color=BLUE]cond[/color] ( ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno)) ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color]) ) ( ([color=BLUE]=[/color] 'ename ([color=BLUE]type[/color] e)) ([color=BLUE]setq[/color] x ([color=BLUE]entget[/color] e)) ([color=BLUE]cond[/color] ( ([color=BLUE]=[/color] 4 ([color=BLUE]logand[/color] 4 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 70 ([color=BLUE]tblsearch[/color] [color=MAROON]"layer"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 8 x))))))) ([color=BLUE]princ[/color] [color=MAROON]"\nObject is on locked layer."[/color]) ) ( ([color=BLUE]=[/color] [color=MAROON]"INSERT"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 x))) (f x) [color=BLUE]t[/color] ) ( ([color=BLUE]princ[/color] [color=MAROON]"\nSelected object is not a block."[/color])) ) ) ) ) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) A clockwise rotation would require an additional prompt, so I suggest it may be quicker to simply click the object 3 times... Quote
Lee Mac Posted May 21, 2013 Posted May 21, 2013 Alternatively, this may be more suitable: ([color=BLUE]defun[/color] c:rb ( [color=BLUE]/[/color] a e f k r x ) ([color=BLUE]setq[/color] a ([color=BLUE]/[/color] [color=BLUE]pi[/color] 2.0)) [color=GREEN];; Default Rotation Angle[/color] ([color=BLUE]initget[/color] [color=MAROON]"X Y Z"[/color]) ([color=BLUE]if[/color] ([color=BLUE]=[/color] [color=MAROON]"Z"[/color] ([color=BLUE]setq[/color] k ([color=BLUE]getkword[/color] [color=MAROON]"\nChoose Block Rotation Axis [X/Y/Z] <X>: "[/color]))) ([color=BLUE]setq[/color] f ([color=BLUE]lambda[/color] ( l [color=BLUE]/[/color] r ) ([color=BLUE]setq[/color] r ([color=BLUE]assoc[/color] 50 l)) ([color=BLUE]entmod[/color] ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] 50 ([color=BLUE]+[/color] a ([color=BLUE]cdr[/color] r))) r l)) ) ) ([color=BLUE]setq[/color] f ([color=BLUE]lambda[/color] ( l [color=BLUE]/[/color] e r ) ([color=BLUE]setq[/color] e ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] -1 l)) r ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 50 l)) ) ([color=BLUE]vlax-invoke[/color] ([color=BLUE]vlax-ename->vla-object[/color] e) 'rotate3d ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 l)) e 0) ([color=BLUE]trans[/color] ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 l)) ([color=BLUE]if[/color] ([color=BLUE]=[/color] [color=MAROON]"Y"[/color] k) ([color=BLUE]list[/color] ([color=BLUE]-[/color] ([color=BLUE]sin[/color] r)) ([color=BLUE]cos[/color] r) 0.0) ([color=BLUE]list[/color] ([color=BLUE]cos[/color] r) ([color=BLUE]sin[/color] r) 0.0) ) ) e 0 ) a ) ) ) ) ([color=BLUE]while[/color] ([color=BLUE]progn[/color] ([color=BLUE]setvar[/color] 'errno 0) ([color=BLUE]initget[/color] [color=MAROON]"Rotation"[/color]) ([color=BLUE]setq[/color] e ([color=BLUE]entsel[/color] [color=MAROON]"\nSelect Block [Rotation] <Exit>: "[/color])) ([color=BLUE]cond[/color] ( ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno)) ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color]) ) ( ([color=BLUE]=[/color] '[color=BLUE]list[/color] ([color=BLUE]type[/color] e)) ([color=BLUE]setq[/color] x ([color=BLUE]entget[/color] ([color=BLUE]car[/color] e))) ([color=BLUE]cond[/color] ( ([color=BLUE]=[/color] 4 ([color=BLUE]logand[/color] 4 ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 70 ([color=BLUE]tblsearch[/color] [color=MAROON]"layer"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 8 x))))))) ([color=BLUE]princ[/color] [color=MAROON]"\nObject is on locked layer."[/color]) ) ( ([color=BLUE]=[/color] [color=MAROON]"INSERT"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 x))) (f x) [color=BLUE]t[/color] ) ( ([color=BLUE]princ[/color] [color=MAROON]"\nSelected object is not a block."[/color])) ) ) ( ([color=BLUE]=[/color] [color=MAROON]"Rotation"[/color] e) ([color=BLUE]if[/color] ([color=BLUE]setq[/color] r ([color=BLUE]getangle[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nSpecify Rotation Angle <"[/color] ([color=BLUE]angtos[/color] a) [color=MAROON]">: "[/color]))) ([color=BLUE]setq[/color] a r) [color=BLUE]t[/color] ) ) ) ) ) ([color=BLUE]princ[/color]) ) ([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color]) Quote
dortega4269 Posted May 21, 2013 Author Posted May 21, 2013 Both bits of code work great, I went with the later based on your comments (more suitable). This makes the process of rotating a block faster! Thanks again Lee Mac. Quote
