Im trying to plot a 3D object in Autocad 2009 but can't remove the hidden lines.
The "Hide" command removes the appropriate lines in the viewport and in the print preview but the print-out still appears with all the lines.
I'm not near my computer right now. But I think if you select the viewport and right-click and then select hidden it should sort it out for you. I also think that there are two options to select 'hidden' in the drop down list, so try both of them.
