I'm hoping someone can help out with this one. I have a LISP that opens a DCL and prompts for user input, then sets the USERI2 variable. If I comment out the "if" function, the DCL works, and the USERI2 is set correctly. As soon as I put the IF back in, I get a "Bad Function" error that I cant seem to locate. Can any one help?
DCL Code:
notiftype : dialog {
label = "Notification Type";
:column	{
  : boxed_radio_column {
  	     label = "Notification Label Selection";
  	     : radio_button {
   		label = "Conventional Notification \"V\"";
   		key = "nconv";
  	     : radio_button {
   		label = "Addressable Notification \"A\"";
   		key = "naddr";
   	ok_cancel;
LISP Code:
(defun c:INDCPLINE (/ r3 nconv naddr )
(setq r3 (getvar "USERI2"))
(if
 (= r3 0)
(setq dcl_id (load_dialog "notiftype.dcl"))
 (if (not (new_dialog "notiftype" dcl_id))(exit))
 	(action_tile "nconv" "(setq nconv $value)(setq nconv (atoi nconv))(setq naddr 0)")
(action_tile "naddr" "(setq naddr $value)(setq naddr (atoi naddr))(setq nconv 0)")
	(action_tile "accept" "(done_dialog 1)")
(action_tile "cancel" "(done_dialog 0)")
(start_dialog)
;  (unload_dialog dcl_id)
 (if (= nconv 1)(COMMAND "userI2" 1))
 (if (= naddr 1)(COMMAND "userI2" 2))
 ;(command "._pline")
I didn't get your idea very well , but can you please try this at the moment ?
(defun c:INDCPLINE (/ r3 nconv naddr)
 (if
   (= r3 0)
        (exit)
      (action_tile
        "nconv"
      (action_tile
        "naddr"
      (start_dialog)
      (if (= nconv 1)
      (if (= naddr 1)
      )                                ;  (unload_dialog dcl_id)
 )                                      ;(command "._pline")
Well, for not "getting my idea", you still made it work :D Thank you VERY VERY MUCH! :notworthy:
:D You're welcome .
It is good to replace the last two functions IF with cond function as the following :
(cond ((= nconv 1)(COMMAND "userI2" 1))
            ((= naddr 1)(COMMAND "userI2" 2))
Good luck .
