Pyro Posted May 8, 2013 Posted May 8, 2013 what is the difference between the student versions and the regular autodesk versions? Quote
ReMark Posted May 8, 2013 Posted May 8, 2013 Other than the Educational banner there should be no difference what-so-ever. Quote
Tyke Posted May 8, 2013 Posted May 8, 2013 Other than the Educational banner there should be no difference what-so-ever. ... and if you open a drawing in the Educational version that was created in a commercial version, the resulting saved file will also display the Educationa Banner, which you can not later remove! Quote
dbroada Posted May 8, 2013 Posted May 8, 2013 as far as I know, nothing. Older student versions did watermark EVERY drawing with a "not for commercial use" message but I believe that has been removed. The watermark would then appear on any drawing openned on any machine that an education drawing was modified on. Not good if you are trying to supply drawings on the cheap. Quote
