Hi,
I am in need of a lisp to do the following
Find the individual area of poly line in layer 1 & Layer 2
Multiply the area in layer 1 by a factor 3.1 and Place text within polyline
Multiply the area in layer 2 by factor 4.1 and Place text within polyline
Sum of text as alert message
Please help me on this..
Thanks in Advance
Suriwaits
Edited by suriwaits
(defun c:areafrom  (/ data TotalArea ss i en area lay)
 (setq data '(("LAYER1" 3.1) ("LAYER2" 4.1)));;<-- change this to.... [of course you know that]
 [b][color="blue"](and  (null unit)				;<-- will only ask you once
   	(not (initget "M MM"))
   	(setq unit (cadr (assoc (getkword  "\nChoos units to use [M/MM]: ") '(("M" 1.0)("MM" 0.000001))))))
 (setq TextHt (cond
((getreal (strcat "\nEnter Text Height"
                (if TextHt (strcat " <" (rtos TextHt) ">: ") ": ")
                           )))(TextHt))
               )[/color][/b]
 (if
   (and
     (setq TotalArea nil
           ss        (ssget '((0 . "LWPOLYLINE") (8 . "LAYER1,LAYER2")))
        (setq en   (ssname ss (setq i (1- i)))
              area [b][color="blue"](* (vlax-curve-getarea en) unit)[/color][/b]
              Lay  (Strcase (cdr (assoc 8 (entget en))))
        (vla-getboundingbox (vlax-ename->vla-object en) 'mn 'mx)
        (setq pt
               (mapcar '(lambda (x y)
               	(* 0.5 (+ x y)))
               (vlax-safearray->list mn)
               (vlax-safearray->list mx)))
        (entmakex (list (cons 0 "TEXT")
                        (cons 10 pt)(cons 8 lay)
                        (cons 11 pt)
                        [b][color="blue"](cons 40 TextHt)
                        '(72 . 1) '(73 . 2) [/color][/b]
                        (cons 1 (rtos (setq area (* (cadr (assoc lay data)) area)) 2 2))
        (setq TotalArea (cons area TotalArea))
        (alert (Strcat "Total area:   " (rtos (apply '+ TotalArea) 2 2)))
Code updated
Edited by pBe
Exactly what i am looking for.
I appreciate you can help me to control the size of text
We can add a prompt for Text Height. Which one did you use? Demo or Demo2?
I used Demo2.
Is it possible to write the area value divided by 1000000 incase i use in mm units.
I used Demo2.
See update code at post # 2
HTH
Awesome!
Thanks agian pBe for your efforts
I have changed factor for mm 0.000001 insted of 0.001 since it is area.
...Thanks agian pBe for your efforts
Oh yeah.. silly me.. Glad i could help :)
