nsc23 Posted April 24, 2013 Posted April 24, 2013 Hi Guys, Trying to remove multiple hatch grips. My problem is as simple as that! Since 2011 brought in the pop-up option, single grips can be removed with this method. But when I want to delete a larger number of grips at once, I can't achieve the required result. Process is as follows: 1. Select Hatch itself 2. Holding SHIFT, select multiple grips (which turn from blue to red) 3. Then 1 left click on a grip, and scrolling through the options using CTRL key until I arrive at 'REMOVE'. Then another left click and nothing happens! Any assistance would help with avoidance of head being done in! Cheers, Clarky. Quote
nsc23 Posted May 1, 2013 Author Posted May 1, 2013 I've since discovered that by moving the grip in question outside the existing hatch area perimeter (anywhere I fancy) it is then removable. But to solve my thread post problem, I'd have to move all the troublesome grips then select them all to delete. Too cumbersome. Quote
