Guys,
I am curious if this has happened to anyone else before...
Whenever i add in a background image (clouds in this case), everything that is reflective becomes see through. Is there a setting that can make this go away? It does it with every, single background image that i've ever used. Recently, i've started to just not use them, but i really need to put a background with some of these for a Job Fair for our company. If you see below, the piping (i know it shouldn't be THAT reflective but that's what they want) becomes slightly see through as well as the hand rails and foot boards...Any thoughts would be great on fixing this. Thanks!
I've attached a second example as well...
