how to make autocad drawing angles automatically
hi
how can i draw this plan without knowing the angles for each wall?
when i draw , the last wall is incorrect
can autocad adjust the angles of walls for me after typing the length of the walls ?
thanks a lot
AutoCAD cannot automatically adjust the angles of the walls as you draw them. The only possible solution I can think of might require using constraints and I'm not 100% that will work either.
If there is enough other information AutoCAD will automatically adjust the angles if Parametric Constraints and Dimensions are used.
I will try to post an example in the next few days.
germacran - you might give it a try yourself - see the Parameters tab.
I would doubt that, even with constraints, anyone could draw that plan. :unsure:
To me, it is a few dimensions short of a plan drawing.
i tried many times but no correct results
You could use snapang but you have to change it every time for a new angle.
If you knew the angles :cry:
