I have inserted an image to a layout for our drawings. On my computer the image shows just fine in the layout. On my co-worker's computer, she doesn't see the image when she opens the same layout. It shows the reference location- example-Z:\Facilties\blah\blah.jpeg
I have AutoCAD 2013 and they have AutoCAD 2014
Is this why there is an issue?
Please help, I want to add this template layout to all our drawings company wide, but if she can't see the image there is a major problem!
Full, Relative or Full path?
What is the file path to the Image?
Does co-worker have access to the folder?
I see the file path where the image should be, it's on a shared drive that my co-worker does have access to. This is why I can't figure it out.
I tried making the image a block- not sure if this will help?
Not sure on if it is a full or relative path
I did find out it was full path- and we tried other ways but it is still not working. is this a version issue?
We open other workers projects all the time it will definately be a problem with your xref path. Only time it does not work is if some one paths to their local pc or a location others have no access to.
It is not a version problem. As a test, put the image in the same folder as the template. AutoCAD will automagically find the file even if the pathing is not correct.
