I have a dynamic block which have some attributes and I'd like to get the contents of the attributes.
For example, if the block has 2 attributes, attr1_size and attr2_color,
and the value of attr1_size is small , and the value of attr2_color is red,
what I need is a list , (attr1_size small)(attr2_color red)
I thought the
(vlax-invoke (vlax-ename->vla-object block_name) 'GetAttributes)
will do this, but the result was like this.
IAcadAttributeReference 0eef3e54>)
Is there any way to get the attribute value from the random sequence?
Or, any other code to get the value?
What I finally want to do is clicking a block and automatically insert some new figures according to the value of an attribute.
Thank you!
e.g.
(if (setq s (ssget "_+.:S:L" '((0 . "INSERT") (66 . 1))))
 (foreach att (vlax-invoke  (vlax-ename->vla-object (ssname s 0)) 'GetAttributes )
   (setq  l (cons (list (vla-get-tagstring att) (vla-get-textstring att))
          l
Thanks, Tharwat ! I added the "vla-get-tagstring" and "vla-get-textstring" in my code!
Now the code is working excellent:D
Thanks, Lee, :)
Your website is one of my best textbook, up until now and forever !
I'm trying to substitute the attributes now, for another code. ;)
You can test the value via an If of the tagstring so only return certain attribute values rather than all not sure if this is where your headed.
(setq ss2 (ssget "x"  '((0 . "INSERT") (2 . "REVTABLE"))))
(setq inc (sslength ss2))
(repeat inc
(foreach att (vlax-invoke (vlax-ename->vla-object (ssname ss2 (setq inc (1- inc)))) 'getattributes)
(if (= oldtag1 (strcase (vla-get-tagstring att)))
(vla-put-textstring att newstr1)
(if (= oldtag2 (strcase (vla-get-tagstring att)))
(vla-put-textstring att newstr2)
(if (= oldtag3 (strcase (vla-get-tagstring att)))
(vla-put-textstring att newstr3)
You're welcome . :)
Thanks, BIGAL !
Now the "vla-put-textstring" is working excellently in my code !! :D
In the description of the block may also be present constants attributes
(defun get-all-atts (obj)
 (if (= (type obj) 'ENAME)
 (setq obj (vlax-ename->vla-object obj)))
 (if (and obj
          (vlax-property-available-p obj 'Hasattributes)
   (eq :vlax-true (vla-get-HasAttributes obj))
   (vl-catch-all-apply
     (function
(lambda ()
  (mapcar (function (lambda (x)
        (cons (vla-get-TagString x)
       (vla-get-TextString x)
   (append (vlax-invoke obj 'Getattributes)
    (vlax-invoke obj 'Getconstantattributes)
  • 9 years later...
  On 4/18/2013 at 7:19 AM, Tharwat said:
e.g.
          l
Expand
hi tharwat,
can u explain this("_+.:s:l")?
thanks advance
  On 4/18/2013 at 11:14 AM, Lee Mac said:
These functions may help: Attribute Functions
Expand
hi lee,
i have been following your website since i started learning autolisp.its really helping me.
(setq sel_ename (car (entsel)))
(setq c_vlaobject (vlax-ename->vla-object sel_ename))
(setq obj (vlax-invoke c_vlaobject 'getattributes))
(setq string (vla-get-tagstring obj))
i sure this is not correct.why i did not get tag string?
can u explain?
thanks advance
  On 1/9/2023 at 5:01 AM, thajmul said:
hi lee,
can u explain?
thanks advance
Expand
(vlax-invoke c_vlaobject 'getattributes) returns a list of objects. So you will have to loop though them to find the tagstings.
Expand
thanks dexus
hi lee,
can u explain?
thanks advance
Expand
I'm pleased that you find my website useful in your studies.
As dexus has subsequently pointed out, the getattributes method will return an array (or list when using vlax-invoke) of attribute reference objects; you'll need to obtain the tagstring property for an object in the list returned. It may be clearer to evaluate each expression through the Visual LISP IDE console, so that you can see the value returned by each expression.
Expand
Thanks for the your kind reply.
