Measuring an angle !
Sorry if this is worded a bit wrong or confusing but how do i measure the angle from point A - B.
Many thanks for any help and input.
Have you tried setting osnap on chose distance - select end A select end B ? All of your distance, angles, etc. will be at the bottom under the command prompt.
This is a Studio Max question, not an Autocad question.
Sorry ignorance showing again I thought that those commands worked in all of AutoCad's programs.
Glad that I have you you and the rest on here that help people to keep me straight.
