Hi, I'm very new to lisp and I'm currently writing some to create steel sections with the main dimensions and the name of the section below.
I'm having trouble adding dimensions (in a new dimension layer) to my lisp file and the text file below my section (also in a new text layer).
Ive attached my lisp file and a picture of what I'm trying to achieve.
Any help would be appreciated!
PFC.pdfFetching info...
pfc.lspFetching info...
Welcome to CadTutor :)
Adjust your dimension style before you invoke the lisp routine to have a very good presentation of the section .
Please let me know how the code runs for you .
(defun c:PFC (/ *error* _Mid p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12)
 ;;----- Tharwat 13. April. 2013 -----;;
 (defun *error* (x)
   (setvar 'cmdecho 1)
   (princ "\n *Cancel*")
 (defun _Mid (a b)
   (mapcar '(lambda (j k) (/ (+ j k) 2.)) a b)
 (if (not (tblsearch "LAYER" "STEEL"))
   (entmake (list '(0 . "LAYER")
                  '(100 . "AcDbSymbolTableRecord")
                  '(100 . "AcDbLayerTableRecord")
                  '(70 . 0)
                  (cons 2 "STEEL")
                  '(62 . 252)
 (if (setq p1 (getpoint "\n Specify base point:"))
     (setvar 'cmdecho 0)
     (entmakex
       (list
         '(0 . "LWPOLYLINE")
         '(100 . "AcDbEntity")
         '(100 . "AcDbPolyline")
         '(8 . "STEEL")
         '(90 . 10)
         '(70 . 1)
         (cons 10 p1)
         '(40 . 0.0)
         '(41 . 0.0)
         '(42 . 0.0)
         (cons 10 (setq p2 (polar p1 0. 90.)))
         '(40 . 0.0)
         '(41 . 0.0)
         '(42 . 0.0)
         (cons 10 (setq p3 (polar p2 (* pi 0.5) 15.)))
         '(40 . 0.0)
         '(41 . 0.0)
         '(42 . 0.0)
         (cons 10 (setq p4 (polar p3 pi 70.)))
         '(40 . 0.0)
         '(41 . 0.0)
         '(42 . -0.414214)
         (cons 10 (setq p5 (polar (polar p4 pi 12.) (* pi 0.5) 12.)))
         '(40 . 0.0)
         '(41 . 0.0)
         '(42 . 0.0)
         (cons 10 (setq p6 (polar p5 (* pi 0.5) 196.)))
         '(40 . 0.0)
         '(41 . 0.0)
         '(42 . -0.414214)
         (cons 10 (setq p7 (polar (polar p6 (* pi 0.5) 12.) 0. 12.)))
         '(40 . 0.0)
         '(41 . 0.0)
         '(42 . 0.0)
         (cons 10 (setq p8 (polar p7 0. 70.)))
         '(40 . 0.0)
         '(41 . 0.0)
         '(42 . 0.0)
         (cons 10 (setq p9 (polar p8 (* pi 0.5) 15.)))
         '(40 . 0.0)
         '(41 . 0.0)
         '(42 . 0.0)
         (cons 10 (setq p10 (polar p9 pi 90.)))
         '(40 . 0.0)
         '(41 . 0.0)
         '(42 . 0.0)
     (command "_.dimlinear"
              "_none"
              (setq p11 (polar (_Mid p5 p6) (* pi 0.5) 25.))
              "_none"
              (setq p12 (polar (_Mid p10 p1) (* pi 0.5) 25.))
              "_none"
              p12
              "_none"
              p10
              "_none"
              p1
              "_none"
              (polar p10 pi 25.)
              "_none"
              p10
              "_none"
              p9
              "_none"
              (polar p10 (* pi 0.5) 15.)
              "_none"
              p9
              "_none"
              p8
              "_none"
              (polar p8 0. 15.)
     (entmakex
       (list '(0 . "MTEXT")
             '(100 . "AcDbMText")
             '(40 . 10.)
             '(71 . 5)
             (cons 7 (getvar 'textstyle))
             '(8 . "STEEL")
             '(42 . 0.0)
             '(50 . 0.)
             (cons 10 (polar (polar p1 0. 45.) (* pi 1.5) 20.))
             '(1 . "{\\L250 PFC}")
     (setvar 'cmdecho 1)
 (princ "\nWritten by Tharwat Al Shoufi")
