motee-z Posted April 11, 2013 Posted April 11, 2013 hi friends is there is an way to create a mesh if available 2 3dpoline or need lisp Quote
f700es Posted April 11, 2013 Posted April 11, 2013 If you have r2012 or higher you can use the new 3D mesh tools. There is an option for mesh smoothing in this tool set. Quote
motee-z Posted April 11, 2013 Author Posted April 11, 2013 thank you for reply ok f700es but how to create mesh if i have 2line of 3dpolyline Quote
GP_ Posted April 12, 2013 Posted April 12, 2013 Connect the ends with a line and then EDGESURF. http://exchange.autodesk.com/autocad/enu/online-help/browse#WS1a9193826455f5ffa23ce210c4a30acaf-4b88.htm Quote
GP_ Posted April 12, 2013 Posted April 12, 2013 You're welcome, motee-z. Consider LOFT command, creates a surface (not mesh) with boundaries that follow exactly the cross sections and it is not necessary to draw the lines for closing. Quote
