jalba Posted April 11, 2013 Posted April 11, 2013 Hi, I'm trying to purge some blocks. I'm successful in deleting them, but after a while they reappear so I have to repurge. Any explanation to this dilemma? Quote
SLW210 Posted April 11, 2013 Posted April 11, 2013 If you are actually purging the block definitions, something must be redefining them. Can you post the .dwg that does this? Quote
jalba Posted April 11, 2013 Author Posted April 11, 2013 ummm....bit of a problem. It's not uploading. Quote
Ski_Me Posted April 11, 2013 Posted April 11, 2013 I've had this problem recently as well I cannot get files to upload. Quote
mostlynice Posted April 12, 2013 Posted April 12, 2013 Use QSELECT to find instances of the block if it's still within the drawing. If not, the block may be associate to another item you're inserting. Also, it can sometimes get confused with external references that have the same file name. Have had problems with this in the past. Quote
jalba Posted April 12, 2013 Author Posted April 12, 2013 No xrefs were attached to the drawing, qselect didn't help. Quote
jalba Posted April 29, 2013 Author Posted April 29, 2013 The majority of the block labels are started with *D eg: *d100, *d18 etc. Quote
ReMark Posted April 29, 2013 Posted April 29, 2013 Posted at www.draftsperson.net *U### = anonymous blocks *E### = anonymous non-uniformly scaled blocks *X### = anonymous hatches *D### = anonymous dimensions *A### = anonymous groups Quote
jalba Posted April 29, 2013 Author Posted April 29, 2013 ok, learning something new. How to get rid of them? Quote
Ski_Me Posted April 29, 2013 Posted April 29, 2013 Pull up the drawing up on your screen. Shoot your screen with a shotgun blocks gone. You may have gotten a drawing that at one time had an xref attached to it. I have a ton of drawings with these and never was able to get rid of them. Did you ever reuse a block that came with the drawing and edit it? That's something I have done before and I would have these phantom blocks reappear after I purged them after I inserted the block into a drawing. Quote
Dadgad Posted April 29, 2013 Posted April 29, 2013 Try using the -PURGE (include the hyphen) command at the commandline. First purge all REGAPPS, and after that choose ALL and purge everything else. You might also want to AUDIT the drawing and save it. You could also set your ISAVEPERCENT to 0 before you save it. Quote
jalba Posted April 29, 2013 Author Posted April 29, 2013 lolz @ ski-me.....ur option could be possible. @dadgad...tried ur techniques, but still not purging all the blocks. I check the items that cannot be purged, and I am seeing a whole bunch of *D's. I try to quick select, but somehow they are non-existent. Quote
ReMark Posted April 29, 2013 Posted April 29, 2013 Can you post a representative drawing file with one of these "unpurgeable" blocks? Quote
dbroada Posted April 29, 2013 Posted April 29, 2013 are you sure that you are not purging them rather than them being recreated by adding or deleting dimensions? That is when I get *D blocks. Quote
jalba Posted April 29, 2013 Author Posted April 29, 2013 i'm not following....represenatble dwg file? Quote
ReMark Posted April 29, 2013 Posted April 29, 2013 Can you please attach a DWG file with one of these blocks, you can't seem to purge, to your next post? Quote
jalba Posted April 29, 2013 Author Posted April 29, 2013 That's the thing Remark, if I select "View items that cannot purge" in the Purge dialog box, I see the names there eg.: *d100 But if i choose to insert *d100, it is not there in my block list. Wish I could attach the file, but having extreme difficulty. Quote
ReMark Posted April 29, 2013 Posted April 29, 2013 It is not all that difficult to attach a DWG file. Start by clicking on the Go Advanced button. Next, click on the Paper Clip icon. Browse to where your file is located and upload it (there are file size limitations). Once uploaded attach to post. A brief explanation or comment is helpful. Submit reply. Done. Quote
Ski_Me Posted April 29, 2013 Posted April 29, 2013 ReMark said: It is not all that difficult to attach a DWG file. Start by clicking on the Go Advanced button. Next, click on the Paper Clip icon. Browse to where your file is located and upload it (there are file size limitations). Once uploaded attach to post. A brief explanation or comment is helpful. Submit reply. Done. He's having the same problem I've been having we can't upload drawings could be size issue but some of the drawings I've tried to upload are not all that big. Doesn't seem to be system wide just a few of us. Quote
