Hi Friends :)
I don't know where to begin
i'm planning fiber optics with autocad, i got problem with deadline :(
(in Attachments i attach file) - there is city map with telecommunication, wells, telecommunication Pole, House, Fiber optics, box whit splitters.
8 House is 1 ring, 1 spliteri serving 8 house (1/8 spliteri)
8 houses encircling the ring is very difficult and takes a lot of time
I want something simple script that would be able to unite in a ring of 8 homes
The script for the map to be ready for the points which should be linked to the spliteri, spliteri be attached to a telephone pole.
i don't know much English to Explained more better :(
The forum could not find anything like this and that is why I have created a new post
If there is a similar post do not ban me admin :(
FTTH-Tbilisi-sanzona-v2.dwg
Edited by alex198617
mistake
Some suggestions not code
1 insert ring
2 pick in clock wise direction next 8 points a line will draw to correct link to ring
Ok some more
insert ring get co-ords of centre of ring work out next 8 pts the join pt to the ring
A start
(seqt inspt (getpoint "\nPick ring point"))
(Command "_insert" "Ring" inspt 1 1 0)
(setq pt1 (polar inspt 3.141593 3.519)) ; polar from pt angle distance
(seqt pt2 (polar inspt 2.703917  3.519))
;pt3-pt8
; DO OTHERS ANGLE IN RADIANS
; do 8 times
(setq pick1 (getpoint "\nPick point))
(command "line" pickpt pt1 "")
(command "line" pickpt pt2 "")
(princ "wow all done")
(defun c:demo (/ p pts pt bn)
(setq angs '(3.14159 2.70392 2.27876 1.84008 1.31112 0.871444 0.443503 0.0))
 (if (and
(tblsearch "BLOCK" "001.SPLICE-1-8+Box")
(tblsearch "BLOCK" "001.SPLICE-1-4+Box")
(setq p (getpoint (strcat "\nPick House nos. " (itoa (setq n 1)))))
(setq pts (cons p pts))
     (while (and (< (length pts)
	  (setq	p_ (getpoint p
				     (itoa (setq n (1+ n)))
				     " <Enter when Done>"
(setq pts (cons p_ pts)
      p	  p_
     (while (eq 5 (car (setq gr (grread T 15 0))))
(setq pt (trans (cadr gr) 1 0))
(redraw)
(foreach px pts
  (grdraw (trans px 0 1) (cadr gr) 1 -1)
     (redraw)
     (if (<= 1 (length pts) 4)
	(setq bn "001.SPLICE-1-4+Box"
	  	angs '(2.27876 1.84008 1.31112 0.871444))
     (vlax-invoke
(vlax-get
  (vla-get-ActiveLayout
    (vla-get-activedocument
      (vlax-get-acad-object)
  'Block
'InsertBlock
pt
(if bn bn "001.SPLICE-1-8+Box") 1 1 1 0
     (mapcar '(lambda (j k)
	 (entmakex (list (cons 0 "LINE")
			 (cons 10 j)
			 (cons 11 (polar pt k 3.5125))
      (reverse pts)
      angs
Same as Bigals' instructions, Clockwise direction.
Also i redefine the block "001.SPLICE-1-8+Box" to make it symmetrical.
DEMO FILE_4&8.dwg
Edited by pBe
Modify to accept splice 4 box
If you're wanting to select the pole instead
MODIFIED TO CREATE LWPOLYLINE
(defun c:demo2 (/ p pts pt bn)
(vl-load-com)
(setq space (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
 (if (and
	  p   p_
  T
(setq pole (ssget "_:S:E" '((0 . "INSERT") (2 . "telasis bodzi"))))
	(setq pt (cdr (assoc 10 (entget (ssname pole 0)))))
     (vlax-invoke space
'InsertBlock pt
	 (setq p2 (polar pt k 3.5125))
		(vlax-invoke
		  space
		  'Addlightweightpolyline
		  (list (car j) (cadr j) (car p2) (cadr p2))
      (reverse pts)
      angs
Now if you want to add VERTICES on the created plines use this: [not sure about the author]
(defun c:adv (/ ent i nlst obj p pt x)
 (vl-load-com)
 (while (setq ent (entsel "\nSelect point on polyline to add vertex: "))
   (if	(and ent (= (cdr (assoc 0 (entget (car ent)))) "LWPOLYLINE"))
     (progn (setq i	(fix (vlax-curve-getparamatpoint
		       (car ent)
		       (setq p (vlax-curve-getclosestpointto (car ent) (cadr ent)))
	   obj	(vlax-ename->vla-object (car ent))
	   pt	(vlax-curve-getpointatparam (car ent) i)
	   nlst	nil
     (mapcar '(lambda (x)
		(if (equal x (list 10 (car pt) (cadr pt)) 0.0001)
		  (setq	nlst (cons x nlst)
			nlst (cons (list 10 (car p) (cadr p)) nlst)
		  (setq nlst (cons x nlst))
	     (entget (car ent))
     (entmod (reverse nlst))
     (entupd (car ent))
     (sssetfirst nil (ssadd (car ent)))
 (sssetfirst nil)
Then stretch the vertex to suit your needs
HTH
Edited by pBe
thank you so much for codes #pBe and #BIGAL :)
the idea/code work perfect "demo2" :) i test it and it's works :) tomorrow i'll try to see who it will cut time for planning
just one edit for "demo2" >
what will be the number for center of object (block>) ? i tried 0.0 but it gose somewhere else
pBe , why did you convert the entity to vla-object in your second routine ?
The values on angs variable are angles and not points. why do you need the center point of the block? [or insertion point?] anyhoo that will be variable pt
....[not sure about the author]....
pBe
what i mean is this
JLgcnnMOtdrvJntB_7A-dR3dOmy9Xl_w-xydgZpUw-QqJeYC5bBCKPPZvxwrfLt_FQ=w1600
and it will be more better with this :)
rJLFyXYclqX0NiZl1KUnIHuq4P5YN7OFHJKVXNA_xRRCx7Y7Lss22AQM7p0ofOlgmQ=w1600
One: if you pick the point at clockwise direction the lines wont cross
Two: what you need is a lot less code
(defun c:demo3 (/ p pts pt bn)
 (vl-load-com)
 (if (and
	  p   p_
  T
     (vlax-invoke
'InsertBlock
pt
(if bn
  bn
1
1
1
0
     (foreach p pts
(entmakex
  (append (list	(cons 0 "LWPOLYLINE")
		(cons 100 "AcDbEntity")
		(cons 100 "AcDbPolyline")
		(cons 90 2)
		(cons 70 0)
	  (mapcar (function (lambda (p) (cons 10 p))) (list pt p))
Now the direction for pick points is irrelevant. :)
thank you my friend ;)
now i'll try make with this code :)
Are not you the author ? :facepalm:
this script works but i have question :/ is it possibly to invert this scrip ? what i mean is to click on "Telasi bodzi" block and he connect with line near by 8 house points ? :unsure:
Not the one you are referring to [c:adv]
Without indicating the house location via pick point? or even selecting the "RED" circles?
I mean, would himself be able to identify nearby buildings.
look pBe i'm very pleased that you help me :) the script is for 2nd task the 1st is that i draw polygon around 8 houses and than is 2nd task (with your help :) )
so if it will be possible to make my 2 task in one :) like click on block and connect near by 8 house and so on ;)
Not sure i understand what that mean alex198617
Ok :) never mined thanks for your help my Friend
show an image like you did before
If I understand you just pick 8 house with pline shape, lots of problems the houses will be returned in the created order not as you see them. Using a select within polygon would give a list of the selected houses but you would need an additional routine to rearrange the list into lower left through to lower right. Maybe with a pick approx center of houses so link block could go anywhere. Pbe what do you think.
;) i finish my one month job in 3 days,
thanks to you pBe :D
  • 7 years later...
Hi there, I came across this conversation and was wondering does this lisp still work?
