trini lawrence Posted April 8, 2013 Posted April 8, 2013 does any one know if a ipad mini can run the autocad program Quote
tzframpton Posted April 8, 2013 Posted April 8, 2013 AutoCAD, no. There is, however, AutoCAD WS in the App Store which might be the fit you're looking for. Quote
Raudel Solis Posted May 8, 2013 Posted May 8, 2013 AutoCAD, no. There is, however, AutoCAD WS in the App Store which might be the fit you're looking for. I read on a site somewhere recently about full versions of Autodesk software running on an Ipad, I didn't pay much attention because I'm not as close to AutoCAD as i used to be. I could not find the original link to what i read, but this link is the exact same thing http://upandready.typepad.com/up_and_ready/2011/06/autocad-2012-full-on-ipad-yes-you-can.html You could also use VNC "remote desktop control/ Virtual Network Computing" applications to access your desktop via internet connection, the only thing wrong with this is Delay. The delay could range from 60 milliseconds to +500 milliseconds depending on the connection speed, and connection type (Hot spot, cellular/ 3g/ satellite/ LAN) Quote
Tiger Posted May 8, 2013 Posted May 8, 2013 AutoCAD WS runs smooth on an iPad Mini, but it is far faar from full AutoCAD. For what it does though, it works fine. Quote
f700es Posted May 8, 2013 Posted May 8, 2013 Correct, as far as I know there is no full AutoCAD that runs on an ARM platform (iPad, iPhones, iPods, Droids and Windows 8 RT). Quote
Raudel Solis Posted May 8, 2013 Posted May 8, 2013 Correct, as far as I know there is no full AutoCAD that runs on an ARM platform (iPad, iPhones, iPods, Droids and Windows 8 RT). Post # 3 is as close as you can get to full autocad Quote
f700es Posted May 8, 2013 Posted May 8, 2013 Post # 3 is as close as you can get to full autocad Yeah that is just a different type of remote desktop so nothing new there. With that logic you can run Revit (insert whatever high end app) on the iPad Quote
