(setq n1(vlax-ldata-put "library1"" name1" 1a))
(setq w1(vlax-ldata-put "library1"" name2" 2a))
(setq h1(vlax-ldata-put "library1" "name3"3a))
 (setq s1(vlax-ldata-put "library1"" name4"4a))
(vlax-ldata-delete "library1"????? )
Please tell me correct code to delete whole library at once
To delete all keys:
(foreach key (vlax-ldata-list "library1")
   (vlax-ldata-delete "library1" (car key))
To remove the dictionary completely:
(dictremove (namedobjdict) "library1")
Thanks Sir, You advises are very helpfully to me.
But there is a problem.
The file was 25kb before delete the library1
after delete it increased to 47kb.
I need to reduce the capacity of file by deleting the library.
I used following code
After reloading the cad it displaying 28kb
Edited by wimal
dictremove will only remove the entry from the supplied dictionary, if you also wish to delete the entity from the drawing database, you will need to use entdel, e.g.:
(if (setq ent (dictremove (namedobjdict) "library1"))
   (entdel ent)
