woohhoo Posted April 2, 2013 Posted April 2, 2013 Hello I tried several ways to let 2 points (cirlces, see image below) following a drawing path (polyline). I tried it with arraypath etc. It doesn't work and I don't find any solution for this problem . Can somebody help me? I work with Autocad 2013. The two circles must follow the polylinepath always with the same distance between the circles. It's like a train or tram movement. The user must be able to enter a certain distance between the objects that has to be copied and the user must also be able to chose how many times it has to be copied. Please, does anyone know a solution? Thx in advance . Quote
woohhoo Posted April 2, 2013 Author Posted April 2, 2013 measure command I tried that too but it doesn't work. Always one circle doesn't follow the path. Quote
Costinbos77 Posted April 2, 2013 Posted April 2, 2013 Do, but insert blocks or AutoCAD dots (points). And do very well. Attached drawing in which you try Quote
eldon Posted April 2, 2013 Posted April 2, 2013 measure command I would have thought that measure would give equal lengths along the curve, but not what the OP requires, which is an equal chord length. I would probably use a suitable block and rotate it for required alignment. Quote
BIGAL Posted April 3, 2013 Posted April 3, 2013 There is a way you place a block on the pline and the 1st insertion pt is cen of circle 2nd rotation pt is calculated and block rotated to this angle, the code is in VBA but I would do now in VL the variable crad is the distance between centres to try make a block called "holden" Sub draw_vehicle() Dim CAR As String Dim arcobj As AcadArc Dim oPoly As AcadEntity Dim blkobj As AcadEntity Dim retVal As Variant Dim snapPt As Variant Dim oCoords As Variant Dim blpnt1() As Variant ReDim blpnt1(100) Dim blpnt2() As Variant ReDim blpnt2(100) Dim vertPt(0 To 2) As Double Dim Pt1(0 To 2) As Double Dim Pt2(0 To 2) As Double Dim newPt(0 To 2) As Double Dim iCnt, w, x, y, z As Integer Dim cRad, interval, blkangle As Double Dim circObj As AcadCircle Dim lineObj As AcadLine On Error GoTo Something_Wrong If ThisDrawing.ActiveSpace = acModelSpace Then Set Thisspace = ThisDrawing.ModelSpace Else: Set Thisspace = ThisDrawing.PaperSpace End If For Each Item In ThisDrawing.Blocks If Item.Name = "holden" Then GoTo continue_on Next Item ' insert holden block InsertBlock "p:\Autodesk\vba\holdencar.dwg", 0 continue_on: w = 1 ThisDrawing.Utility.GetEntity oPoly, snapPt, vbCr & "Select polyline :" If oPoly.ObjectName = "AcDbPolyline" Then oCoords = oPoly.Coordinates Else: MsgBox "This object is not a polyline! Please do again" Exit Sub End If interval = CDbl(InputBox("Enter interval:", , 1#)) If interval < 1 Then interval = 1 End If For iCnt = 0 To UBound(oCoords) - 2 Step 2 Pt1(0) = oCoords(iCnt): Pt1(1) = oCoords(iCnt + 1): Pt1(2) = 0# newPt(0) = Pt1(0) newPt(1) = Pt1(1) newPt(2) = 0# iCnt = iCnt + 2 Pt2(0) = oCoords(iCnt): Pt2(1) = oCoords(iCnt + 1): Pt2(2) = 0# x = (Pt1(0) - Pt2(0)) / interval y = (Pt1(1) - Pt2(1)) / interval 'reset back 2 values iCnt = iCnt - 2 cRad = 3.05 startang = 4.71239 endang = 1.570796 CAR = "HOLDEN" For z = 1 To interval vertPt(0) = newPt(0) - x vertPt(1) = newPt(1) - y vertPt(2) = 0# 'blpnt1(w) = vertPt 'Set arcobj = ThisDrawing.ModelSpace.AddArc(vertPt, cRad, endang, startang) Set arcobj = Thisspace.AddArc(vertPt, cRad, endang, startang) retval2 = arcobj.IntersectWith(oPoly, acExtendOtherEntity) arcobj.Delete Set arcobj = Nothing blkangle = ThisDrawing.Utility.AngleFromXAxis(retval2, vertPt) 'Set blkobj = ThisDrawing.ModelSpace.InsertBlock(vertPt, CAR, 1#, 1#, 1#, blkangle) Set blkobj = Thisspace.InsertBlock(vertPt, CAR, 1#, 1#, 1#, blkangle) Set blkobj = Nothing w = w + 1 newPt(0) = newPt(0) - x newPt(1) = newPt(1) - y Next z Next iCnt GoTo Exit_out Something_Wrong: MsgBox Err.Description Exit_out: End Sub Private Sub InsertBlock1() '**************************************** '*** Code from VisibleVisual.com ******** '**************************************** InsertBlock "p:\Autodesk\vbaholden.dwg", 0 'Change the 0 to another value (in degrees) to rotate the block' End Sub Function InsertBlock(ByVal blockpath As String, ByVal rotation As Double) Dim blockobj As AcadBlockReference Dim insertionPnt As Variant Dim prompt1 As String 'set rotation Angle rotateAngle = rotation 'rotateAngle = rotation * 3.141592 / 180# 'Prompt is used to show instructions in the command bar prompt1 = vbCrLf & "Enter block insert point: " 'ThisDrawing.ActiveSpace = acModelSpace insertionPnt = ThisDrawing.Utility.GetPoint(, prompt1) Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, blockpath, 1#, 1#, 1#, rotateAngle) 'Change Modelspace into Paperspace to insert the block into Paperspace End Function Quote
woohhoo Posted April 3, 2013 Author Posted April 3, 2013 Do, but insert blocks or AutoCAD dots (points). And do very well. Attached drawing in which you try Hi, below the autocadfile 2pointspath.dwg Quote
woohhoo Posted April 3, 2013 Author Posted April 3, 2013 I would have thought that measure would give equal lengths along the curve, but not what the OP requires, which is an equal chord length. I would probably use a suitable block and rotate it for required alignment. That's what I'm doing now. But sometimes it's more than one block and it takes a lot of time and sometimes you snap to the wrong line . Therefor, with a lisproutine (if it's possible) you don't make a mistake Quote
woohhoo Posted April 3, 2013 Author Posted April 3, 2013 There is a way you place a block on the pline and the 1st insertion pt is cen of circle 2nd rotation pt is calculated and block rotated to this angle, the code is in VBA but I would do now in VL the variable crad is the distance between centres to try make a block called "holden" Sub draw_vehicle() Dim CAR As String Dim arcobj As AcadArc Dim oPoly As AcadEntity Dim blkobj As AcadEntity Dim retVal As Variant Dim snapPt As Variant Dim oCoords As Variant Dim blpnt1() As Variant ReDim blpnt1(100) Dim blpnt2() As Variant ReDim blpnt2(100) Dim vertPt(0 To 2) As Double Dim Pt1(0 To 2) As Double Dim Pt2(0 To 2) As Double Dim newPt(0 To 2) As Double Dim iCnt, w, x, y, z As Integer Dim cRad, interval, blkangle As Double Dim circObj As AcadCircle Dim lineObj As AcadLine On Error GoTo Something_Wrong If ThisDrawing.ActiveSpace = acModelSpace Then Set Thisspace = ThisDrawing.ModelSpace Else: Set Thisspace = ThisDrawing.PaperSpace End If For Each Item In ThisDrawing.Blocks If Item.Name = "holden" Then GoTo continue_on Next Item ' insert holden block InsertBlock "p:\Autodesk\vba\holdencar.dwg", 0 continue_on: w = 1 ThisDrawing.Utility.GetEntity oPoly, snapPt, vbCr & "Select polyline :" If oPoly.ObjectName = "AcDbPolyline" Then oCoords = oPoly.Coordinates Else: MsgBox "This object is not a polyline! Please do again" Exit Sub End If interval = CDbl(InputBox("Enter interval:", , 1#)) If interval < 1 Then interval = 1 End If For iCnt = 0 To UBound(oCoords) - 2 Step 2 Pt1(0) = oCoords(iCnt): Pt1(1) = oCoords(iCnt + 1): Pt1(2) = 0# newPt(0) = Pt1(0) newPt(1) = Pt1(1) newPt(2) = 0# iCnt = iCnt + 2 Pt2(0) = oCoords(iCnt): Pt2(1) = oCoords(iCnt + 1): Pt2(2) = 0# x = (Pt1(0) - Pt2(0)) / interval y = (Pt1(1) - Pt2(1)) / interval 'reset back 2 values iCnt = iCnt - 2 cRad = 3.05 startang = 4.71239 endang = 1.570796 CAR = "HOLDEN" For z = 1 To interval vertPt(0) = newPt(0) - x vertPt(1) = newPt(1) - y vertPt(2) = 0# 'blpnt1(w) = vertPt 'Set arcobj = ThisDrawing.ModelSpace.AddArc(vertPt, cRad, endang, startang) Set arcobj = Thisspace.AddArc(vertPt, cRad, endang, startang) retval2 = arcobj.IntersectWith(oPoly, acExtendOtherEntity) arcobj.Delete Set arcobj = Nothing blkangle = ThisDrawing.Utility.AngleFromXAxis(retval2, vertPt) 'Set blkobj = ThisDrawing.ModelSpace.InsertBlock(vertPt, CAR, 1#, 1#, 1#, blkangle) Set blkobj = Thisspace.InsertBlock(vertPt, CAR, 1#, 1#, 1#, blkangle) Set blkobj = Nothing w = w + 1 newPt(0) = newPt(0) - x newPt(1) = newPt(1) - y Next z Next iCnt GoTo Exit_out Something_Wrong: MsgBox Err.Description Exit_out: End Sub Private Sub InsertBlock1() '**************************************** '*** Code from VisibleVisual.com ******** '**************************************** InsertBlock "p:\Autodesk\vbaholden.dwg", 0 'Change the 0 to another value (in degrees) to rotate the block' End Sub Function InsertBlock(ByVal blockpath As String, ByVal rotation As Double) Dim blockobj As AcadBlockReference Dim insertionPnt As Variant Dim prompt1 As String 'set rotation Angle rotateAngle = rotation 'rotateAngle = rotation * 3.141592 / 180# 'Prompt is used to show instructions in the command bar prompt1 = vbCrLf & "Enter block insert point: " 'ThisDrawing.ActiveSpace = acModelSpace insertionPnt = ThisDrawing.Utility.GetPoint(, prompt1) Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, blockpath, 1#, 1#, 1#, rotateAngle) 'Change Modelspace into Paperspace to insert the block into Paperspace End Function Thx, but I don't know how to start or how to run a VBA program on my Autocad. Anyway, I hope you will succeed in VL Here's the autocadfile 2pointspath.dwg Quote
Costinbos77 Posted April 3, 2013 Posted April 3, 2013 (edited) Your problem is more complicated because you have to align block "TEMP" (which does not have the same length in the direction of x and y) from the point of insertion and a calculated point at a distance equal to the length of the block. Edited April 3, 2013 by Costinbos77 Quote
BIGAL Posted April 3, 2013 Posted April 3, 2013 I am redoing to match "temp" Any way a quick way insert block make sure insertion point is center of 1 circle then draw a circle 7.0 units rotate the block using Ro R the crossing point is the correct angle. My version draws lots of blocks its for checking purposes. Constinboss77 have a look at the code thats what it does rotates the block to suit. Quote
woohhoo Posted April 3, 2013 Author Posted April 3, 2013 Your problem is more complicated because you have to align block "TEMP" from the point of insertion and a calculated point at a distance equal to the length of the block. I know and it doesn't work with a normal Autocad commando Quote
BIGAL Posted April 3, 2013 Posted April 3, 2013 Revised have a look at this Type VBAMAN New pick the global1, visual basic editor, double click the global1 top left the code window should open paste code & save to see result use the RUN sub/userform try 1 for interval. Its more about the method of how to do. You will need a new vertices lsp as well to work out how many you display and at what spacing. Time at moment is a problem for a complete solution. Sub draw_vehicle() Dim CAR As String Dim arcobj As AcadArc Dim oPoly As AcadEntity Dim blkobj As AcadEntity Dim retVal As Variant Dim snapPt As Variant Dim oCoords As Variant Dim blpnt1() As Variant ReDim blpnt1(100) Dim blpnt2() As Variant Dim vertPt(0 To 2) As Double Dim Pt1(0 To 2) As Double Dim Pt2(0 To 2) As Double Dim newPt(0 To 2) As Double Dim iCnt, w, x, y, z As Integer Dim cRad, interval, blkangle As Double Dim circObj As AcadCircle Dim lineObj As AcadLine On Error GoTo Something_Wrong For Each Item In ThisDrawing.Blocks If Item.Name = "temp" Then GoTo continue_on Next Item ' exits out of program GoTo Exit_out continue_on: w = 1 ThisDrawing.Utility.GetEntity oPoly, snapPt, vbCr & "Select polyline :" If oPoly.ObjectName = "AcDbPolyline" Then oCoords = oPoly.Coordinates Else: MsgBox "This object is not a polyline!" Exit Sub End If interval = CDbl(InputBox("Enter interval:", , 1#)) If interval < 1 Then interval = 1 End If For iCnt = 0 To UBound(oCoords) - 2 Step 2 Pt1(0) = oCoords(iCnt): Pt1(1) = oCoords(iCnt + 1): Pt1(2) = 0# newPt(0) = Pt1(0) newPt(1) = Pt1(1) newPt(2) = 0# iCnt = iCnt + 2 Pt2(0) = oCoords(iCnt): Pt2(1) = oCoords(iCnt + 1): Pt2(2) = 0# x = (Pt1(0) - Pt2(0)) / interval y = (Pt1(1) - Pt2(1)) / interval 'reset back 2 values iCnt = iCnt - 2 cRad = 7# startang = 4.7123889 endang = 1.57079632 CAR = "temp" For z = 1 To interval vertPt(0) = newPt(0) - x vertPt(1) = newPt(1) - y vertPt(2) = 0# 'blpnt1(w) = vertPt Set arcobj = ThisDrawing.ModelSpace.AddArc(vertPt, cRad, endang, startang) retval2 = arcobj.IntersectWith(oPoly, acExtendOtherEntity) arcobj.Delete Set arcobj = Nothing blkangle = ThisDrawing.Utility.AngleFromXAxis(retval2, vertPt) Set blkobj = ThisDrawing.ModelSpace.InsertBlock(vertPt, CAR, 1#, 1#, 1#, blkangle) Set blkobj = Nothing w = w + 1 newPt(0) = newPt(0) - x newPt(1) = newPt(1) - y Next z Next iCnt Something_Wrong: MsgBox Err.Description Exit_out: End Sub Quote
