mostafa badran Posted April 1, 2013 Posted April 1, 2013 assalam alaikum I need help to make fillet for multiple lines like image attached, in one click to fillet them all Quote
marko_ribar Posted April 1, 2013 Posted April 1, 2013 You could create one fillet and convert it to polyline... Then you can just do multiple offset on that pline... M.R. Quote
mostafa badran Posted April 1, 2013 Author Posted April 1, 2013 I mean fillet all lines when I select all lines in one click not by use offset command Quote
Baber62 Posted April 2, 2013 Posted April 2, 2013 Does the fillet radius increase or are you keeping the fillet radius the same? If you are keeping it the same fillet radius then I would invoke the "multiple" command at the command line and then type in fillet for the command to be repeated and follow the steps from there. Quote
BIGAL Posted April 3, 2013 Posted April 3, 2013 A method via lisp is to drag two lines over the lines, you can then decide 1 fillet rad or a seed radius which changes depending on the spacing between the lines, basicly you can have as many lines as you like so long as they are pairs. Quote
Baber62 Posted April 3, 2013 Posted April 3, 2013 @BIGAL Do you have the lisp coding? Please can you post it. Quote
mostafa badran Posted April 3, 2013 Author Posted April 3, 2013 (edited) Please read the CODE POSTING GUIDELINES and use Code Tags. ;;;--------------------------------------------------------------------------- ;;; ;;; autokerb rad.LSP Version 1.0 ;;; by Alan H ;;; 1 Aug 2011 ;;; uses fillet given inside radius for any number of lines ;;; ;;;--------------------------------------------------------------------------- (defun C:krad (/ CM EN EN2 NUM OLDSNAP PT1 PT2 PT3 RAD SS1 SS2 TP1 TP2 ANS NUM2 PT4 X Y) (vl-load-com) (setq cm (getvar "cmdecho")) (setvar "cmdecho" 1) (setq oldsnap (getvar "osmode")) (setvar "osmode" 0) (setq pt1 (getpoint "\nPick outside first kerb :")) (setq pt2 (getpoint Pt1 "\nPick centre pt :")) (setq pt3 (getpoint pt2 "\nPick outside second kerb :")) (setq rad (getreal "\nEnter radius :")) (setq ss1 (ssget "F" (list pt1 pt2))) (setq ss2 (ssget "F" (list pt3 pt2))) (setq num (sslength ss1)) (setq num2 (sslength ss2)) (if (/= num num2) (progn (princ "\nYou have unequal number of lines ") (Setq ans (getstring "\Press any key when ready and try again")) (exit) ) ) (repeat num (setq en (ssname ss1 0)) (setq en2 (ssname ss2 0)) (setq tp1 (cons (vlax-curve-getClosestPointTo en pt2) tp1)) (setq tp2 (cons (vlax-curve-getClosestPointTo en2 pt2) tp2)) (ssdel en ss1) ; Delete each measured entity from set (ssdel en2 ss2) ; Delete each measured entity from set ) ; end repeat (reverse tp2) (setq pt1 (nth 0 tp1)) (setq pt2 (nth 0 tp2)) (setvar "filletrad" rad) (command "fillet" pt1 pt2) (setq num (- num 1)) (setq x 0) (repeat num (setq pt1d (nth x tp1)) (setq pt2d (nth (+ x 1) tp1)) (setq rad (+ rad (distance pt1d pt2d))) ; add distance between to rad (setvar "filletrad" rad) (setq pt1 (nth (+ x 1) tp1)) (setq pt2 (nth (+ x 1) tp2)) (command "fillet" pt1 pt2) (setq x (+ x 1)) ) ; end repeat (setvar "CMDECHO" cm) (setvar "osmode" oldsnap) ) (princ) Edited April 3, 2013 by SLW210 Added Code Tags!! Quote
marko_ribar Posted April 3, 2013 Posted April 3, 2013 mostafa, I thought it was you who asked the same on http://www.augi.com ... Irneb have great solution, but keep in mind that you must watch how you pick points with fence selections (you must supply it in correct relations as mfillet may finish in opposite direction as it should)... http://forums.augi.com/showthread.php?44929-Looking-for-a-routine-for-Multiple-Fillet&p=#7 M.R. Quote
mostafa badran Posted April 3, 2013 Author Posted April 3, 2013 (edited) thank you............... Edited April 3, 2013 by mostafa badran Quote
BIGAL Posted April 4, 2013 Posted April 4, 2013 Recognised that code known as kerbrad.lsp the original code was done to fillet road kerbs a task we often do for car parks. You can do as many lines as you like the lines do not have to actually have same offsets on the second group but it will base its fillet rad's on the first crossing selection. A single pick is possible by using a circle only problem is how big a circle ? The original code non Vl was written 20 years ago. Quote
