Save Duplicate DWG LISP Routine
lamensterms
Hey guys,
I found this thread on the Audodesk forums the other day…http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Save-copy-of-AutoCAD-Dwg-file-using-macro/td-p/3574830
And thought it looked like a pretty good idea. So I applied the macro code to a QuickSave LISP routine and found that it does work quite well.
One thing which is puzzling me… sometimes I get the message “A drawing with this name already exists. Do you want to replace it?” returned in the command line, other times I get no message and the routine completes successfully. My first thought was that I would only (and always) get that message when the message is true – when a file needs to be overwritten. This is not the case, sometimes I can run the routine, there can be an existing file of the same name in my “BackUp” directory, and I will not see the ‘overwrite’ message.
My code is:
(defun c:q ()
(vl-load-com)
(command "qsave")
(SETQ QSDATE (RTOS (GETVAR "CDATE") 2 0))
(vl-mkdir (strcat "D:/_DWGBackup/" QSDATE "/"))
(command "_.SAVE" (strcat "D:/_DWGBackup/" QSDATE "/" (getvar "DWGNAME")))
I have since found a work-around (code below) for this problem, so it is not a solution that I seek – just and explanation as to why I would only sometimes get that message.
(DEFUN C:q (/ newname)
  (setvar "CMDECHO" 0)
  (if (zerop (getvar "dwgtitled"))
	(command "._qsave" (getstring "\n Enter drawing name: "))
	(command "_.qsave")
  (setvar "filedia" 0)
  (setq newname
		(strcat
		  (getvar "DWGNAME")
  (if (findfile (strcat newname))
	(command "_.save" newname "_Y")
	(command "_.save" newname)
  (setvar "filedia" 1)
Thanks for any help.
(setvar 'expert 2) ..Jeez, now im confused :D
That's it - thanks pBe.
Glad i could help :)
