samifox Posted March 22, 2013 Share Posted March 22, 2013 Hi I search the net for a lisp for adding or distributing verticesalong a polyline, but I couldn’t find something that is close enough to what I need. I simply need to add vertices along a polyline by defining alength between them. Exactly as the measure command does to a poly , but insteadof dots I need it to be vertices Thanks Shay Quote Link to comment Share on other sites More sharing options...
BlackBox Posted March 22, 2013 Share Posted March 22, 2013 Consider the AddVertex Method as a starting point. Quote Link to comment Share on other sites More sharing options...
samifox Posted March 22, 2013 Author Share Posted March 22, 2013 i was hoping some can drop some lines as i dont know to program visal basic Quote Link to comment Share on other sites More sharing options...
pBe Posted March 22, 2013 Share Posted March 22, 2013 (Defun c:demo () (if (and (setq pline (car (entsel "\nSelect Polyline:"))) (eq (cdr (assoc 0 (entget pline))) "LWPOLYLINE") (setq int (getdist "\nEnter Interval:")) (setq in int) ) (while (Setq pt (vlax-curve-getPointAtDist pline int)) (setq ppt (vlax-curve-getparamatpoint pline pt)) (vlax-invoke (vlax-ename->vla-object pline) 'AddVertex (1+ (fix ppt)) (list (car pt) (Cadr pt)) ) (setq int (+ int in)) ) ) ) Quote Link to comment Share on other sites More sharing options...
samifox Posted March 22, 2013 Author Share Posted March 22, 2013 The script working greate! Thanks a milion friend Quote Link to comment Share on other sites More sharing options...
pBe Posted March 22, 2013 Share Posted March 22, 2013 The script working greate! Thanks a milion friend Cheers samifox, Glad i could help. Quote Link to comment Share on other sites More sharing options...
samifox Posted March 29, 2013 Author Share Posted March 29, 2013 (Defun c:demo () (if (and (setq pline (car (entsel "\nSelect Polyline:"))) (eq (cdr (assoc 0 (entget pline))) "LWPOLYLINE") (setq int (getdist "\nEnter Interval:")) (setq in int) ) [b][color=red](while (Setq pt (vlax-curve-getPointAtDist pline int)) (setq ppt (vlax-curve-getparamatpoint pline pt)) (vlax-invoke (vlax-ename->vla-object pline) 'AddVertex (1+ (fix ppt)) (list (car pt) (Cadr pt)) ) (setq int (+ int in)) ) ) ) [/color][/b] hello im analyzing your code , i need help with the second paragraph just after the "while loop". how vlax-curve-getPointAtDist and vlax-curve-getparamatpoint are being used here? Thanks Shay 1 Quote Link to comment Share on other sites More sharing options...
samifox Posted April 1, 2013 Author Share Posted April 1, 2013 hi this code ask the user for interval and than distribute verts along the poly, but the interval is not quite precise because its being rounded by the fix() every iteration. im trying to implement this code in my project but this problem cannot be solved in this way. can someone post a code that does the same but with respect to all decimal digits and without rounding off? Thanks Shay Quote Link to comment Share on other sites More sharing options...
pBe Posted April 1, 2013 Share Posted April 1, 2013 The function fix on this particular code pertains to the segment number samifox. a point after the fact. Show me and post a sample drawing where the result is not precise and lets see what we can do to "fix" the code (pun intended) Quote Link to comment Share on other sites More sharing options...
samifox Posted April 1, 2013 Author Share Posted April 1, 2013 code ask for point a and b and for polylines, than it sends points a and b to be divided and returns what is the segment length and the number of segments. than it adds verts as the number of the segments and (suppose to) distribute them in segment length interval you can see the xlines are distribute correctly but the verts are not. i want the verts to be distribute exactly as the xlines Thanks Shay (vl-load-com) (defun c:m () (setq userData (wl:getUserData)) (setq proData (extractSegment userData 6.0 8.0)) (drawVers userData proData) ) (defun wl:getUserData (/ ptst pten) (if (setq ptst (getpoint "\nStart point of path: ")) (if (setq pten (getpoint ptst "\nEndpoint of path: ")) (progn ;(setq ptst (trans ptst 1 0) pten (trans pten 1 0)) (setq wall (getPoly wall "\nSelect Wall eleveation line")) (setq front (getPoly front "\nSelect Front eleveation line")) (setq back (getPoly back "\nSelect Back eleveation line")) (setq exist (getPoly exist "\nSelect Exist eleveation line")) (list (cons 10 ptst) (cons 11 pten) (cons 41 (distance ptst pten)) (cons 51 wall) (cons 52 front) (cons 53 back) (cons 54 exist) ) ;_list ) ;_progn ) ;_if endpt ) ;_if strp ) ;_defun (defun getPoly (ent msg) (if (setq ent (car (entsel msg))) (if (eq (cdr (assoc 0 (entget ent))) "LWPOLYLINE") ent ) ;_if (alert "\nThe selected object is not a polyline") ) ;_if ) ;_defun ;_______________________________________________________________________________________________________ (defun extractSegment (userData minv maxv / ptst pten d n6 n8 n1 n2 n k stpt enpt) (setq ptst (cdr (assoc 10 userData))) (setq pten (cdr (assoc 11 userData))) (setq d (cdr (assoc 41 userData))) ;getiing unrestricted devition (setq n6 (/ d 6.0)) (setq n8 (/ d 8.0)) (cond ( (equal n6 1.0 1e-15);what is 1e-15??? (setq n 1.0) ) ( (and (null n) (> n6 1.0)) (setq n1 (fix n8) n2 (+ (fix n6) 1)) (repeat (+ (- n2 n1) 1) (if (<= 6.0 (if (/= n1 0) (/ d (float n1)) 0.0) 8.0) (setq n n1) (if (null n) (setq n nil)) ) (setq n1 (1+ n1)) ) ) ( (< n6 1.0) (setq n nil) ) ) (if n (progn (setq k -1.0) (repeat (fix n) (setq stpt (mapcar '+ ptst (mapcar '* (mapcar '/ (mapcar '- pten ptst) (list n n n)) (list (setq k (1+ k)) k k)))) (setq enpt (mapcar '+ stpt (mapcar '/ (mapcar '- pten ptst) (list n n n)))) (entmake (list '(0 . "LINE") '(62 . 1) (cons 10 stpt) (cons 11 enpt) (list 210 0.0 0.0 1.0))) (command "xline" "V" stpt "") ) ) (prompt "\nOriginal line couldn't be divided into lines with 6-8 units lengths criteria") ) (list (cons 81 n) (cons 82 (distance stpt enpt) ) ) ) ;_______________________________________________________________________________________________________ (Defun drawVers (userData proData) (setq wall (cdr (assoc 51 userData))) (setq front (cdr (assoc 52 userData))) (setq back (cdr (assoc 53 userData))) (setq exist (cdr (assoc 54 userData))) (setq seglen (cdr (assoc 82 proData)) ) (setq segcnt (cdr (assoc 81 proData)) ) (setq in segcnt) (while (Setq pt (vlax-curve-getPointAtDist wall seglen)) (setq ppt (vlax-curve-getparamatpoint wall pt)) (vlax-invoke (vlax-ename->vla-object wall) 'AddVertex (1+ (fix ppt)) (list (car pt) (Cadr pt)) ) (setq seglen (+ seglen in)) ) ) Quote Link to comment Share on other sites More sharing options...
pBe Posted April 1, 2013 Share Posted April 1, 2013 I don't get it samifox. what exactly does it do? Show me and post a sample drawing Quote Link to comment Share on other sites More sharing options...
samifox Posted April 1, 2013 Author Share Posted April 1, 2013 I don't get it samifox. what exactly does it do? im my dally work i do all the steps the code does. they are all predictable so they can be coded. im working in a construction firm, so the architect give us his drawing with the wall and the elevation in front and in the back of the wall. our work is to measure the distance between the front and the back elevation and contract a base wall underground to hold the wall. so the code ask the wall distance and the front and back lines, than divide the distance into smaller segments , by dividing that i know what is each segment length and how many segment there are. than i want to distribute vertices along the back and front lines so i can know the Y of each elevation on each segment, if i know the info i can than program how to draw and under what conditions hope its clear the problem: for some reason the verts are not distribute correctly, the segment length should be the interval but its not maybe if you can explain to me the second paragraph (RED) of your code it will help me to troubleshot it Thanks Shay Quote Link to comment Share on other sites More sharing options...
pBe Posted April 1, 2013 Share Posted April 1, 2013 First glance. Osnaps There's a reason why i'm asking for a sample drawing or an [image if you prefer], so that we wont be postings questions and answers back and forth. Understanding what you are trying to do will make it easier for us here to give you the appropriate solution. Anyhoo... maybe if you can explain to me the second paragraph (RED) of your code it will help me to troubleshot it Like i 've said. FIX had nothing to do with the interval value.. [not directly that is]. I'll suggest you read up on vlax-curve-getPointAtDist and vlax-curve-getparamatpoint on the help file and tell me what part of that you're having trouble understanding. Quote Link to comment Share on other sites More sharing options...
samifox Posted April 1, 2013 Author Share Posted April 1, 2013 sorry i was thinking i need the code. i post it thanks shay m.dwg Quote Link to comment Share on other sites More sharing options...
pBe Posted April 1, 2013 Share Posted April 1, 2013 Sorry dude, still don't get it. Try this link. 7-10[/b]] http://www.cadtutor.net/forum/showthread.php?78119-Intersection-of-a-vertical-lines-and-a-polyline. Me think that's what you're after. Cheers Quote Link to comment Share on other sites More sharing options...
troggarf Posted April 1, 2013 Share Posted April 1, 2013 The code works great PBE I don't have an immediate use for it but it does work just fine when I tested it Thanks ~Greg (Defun c:demo () (if (and (setq pline (car (entsel "\nSelect Polyline:"))) (eq (cdr (assoc 0 (entget pline))) "LWPOLYLINE") (setq int (getdist "\nEnter Interval:")) (setq in int) ) (while (Setq pt (vlax-curve-getPointAtDist pline int)) (setq ppt (vlax-curve-getparamatpoint pline pt)) (vlax-invoke (vlax-ename->vla-object pline) 'AddVertex (1+ (fix ppt)) (list (car pt) (Cadr pt)) ) (setq int (+ int in)) ) ) ) Quote Link to comment Share on other sites More sharing options...
samifox Posted April 1, 2013 Author Share Posted April 1, 2013 you can see those points? they supposed to be destitute exactly like the lines. Quote Link to comment Share on other sites More sharing options...
samifox Posted April 1, 2013 Author Share Posted April 1, 2013 (Defun c:demo () (if (and (setq pline (car (entsel "\nSelect Polyline:"))) (eq (cdr (assoc 0 (entget pline))) "LWPOLYLINE") (setq int (getdist "\nEnter Interval:")) (setq in int) ) [color=red][b](while (Setq pt (vlax-curve-getPointAtDist pline int)) (setq ppt (vlax-curve-getparamatpoint pline pt)) (vlax-invoke (vlax-ename->vla-object pline) 'AddVertex (1+ (fix ppt)) (list (car pt) (Cadr pt)) ) (setq int (+ int in)) )[/b][/color] ) ) thanks for your timr dude here the lines i dont understand (RED) after getting the poly id and interval info you assign in to int why? (than the while loops until nill) pt get the first point according to the interval ppt than get the distance up to this point than you invoke conversion and the call AddVertex than you advance ppt by 1 , why? than you make a list of the entity, why? (its open to everyone:) ) Thanks Shay Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted April 1, 2013 Share Posted April 1, 2013 samifox, after examining your code, me think you should change (setq in segcnt) to (setq in seglen) After, you should test your code again... M.R. Quote Link to comment Share on other sites More sharing options...
samifox Posted April 1, 2013 Author Share Posted April 1, 2013 Mario...do you know you are my king!!! Thank for reading thru all the thread You make my day God bless you shay Quote Link to comment Share on other sites More sharing options...
