f700es Posted March 21, 2013 Posted March 21, 2013 Ok, pretty simple. Let's all share our AutoCAD screen shots. Keep it simple. What you see each morning when you start AutoCAD up. No work images just the default dwg. Quote
rkent Posted March 26, 2013 Posted March 26, 2013 f700es said: Ok, pretty simple. Let's all share our AutoCAD screen shots. Keep it simple. What you see each morning when you start AutoCAD up. No work images just the default dwg. No takers? f700es you didn't post your own either, here is mine. Quote
f700es Posted March 27, 2013 Author Posted March 27, 2013 rkent said: No takers? f700es you didn't post your own either, here is mine. Yeah I wanted someone else to be 1st since I started the thread. Here is my 2012 startup from work. I'll add my 2013 and 2014 screens when I can. Quote
dbroada Posted March 27, 2013 Posted March 27, 2013 I'm new to 2013 and trying to find where to put my 2 toolbars but this is close... Quote
Glen1980 Posted April 9, 2013 Posted April 9, 2013 Here is mine, I mostly use key commands so the only toolbars I have are for swapping styles. The icons on the QAT are mostly for Macros. Incidently how do I take a screen shot of my second screen, the best I can do is capture the individual boxes? I have the tool pallet the full height of the right hand side roughly 1/3 width of the screen, my command line at the bottom of the screen 2/3 width of the screen with the properties pallet and the xref pallets next to each other in the remaining space. Quote
Tiger Posted April 10, 2013 Posted April 10, 2013 Two screens, everything else on the other. There really shouldn't be anything on the other (today I have Xref Manager and Layer Manager up but I really should remember to close them more often. Jrn - I will just assume you work with beer Quote
Tiger Posted April 10, 2013 Posted April 10, 2013 guran said: Here is mine That is quite possibly the most sparse UI I have seen! Quote
guran Posted April 10, 2013 Posted April 10, 2013 A screen, keyboard, QAT and dynamic input. What more do you need? Quote
guran Posted April 10, 2013 Posted April 10, 2013 Sorry! Forgot the quick properties and right click menues. Quote
Glen1980 Posted April 10, 2013 Posted April 10, 2013 guran said: Here is mine [ATTACH=CONFIG]41345[/ATTACH] Blimey, I have something to learn on the spartan screen setup! Don't you ever miss the command line? Quote
dbroada Posted April 10, 2013 Posted April 10, 2013 Glen1980 said: Blimey, I have something to learn on the spartan screen setup! Don't you ever miss the command line?I don't, and you always have F2. Quote
Glen1980 Posted April 10, 2013 Posted April 10, 2013 Good point Dave. I must say that I do like to check sometimes I've typed the correct custom alias, especially when it's a command I don't use that often (very bad memory.) Are you back on at work now Dave? Quote
guran Posted April 10, 2013 Posted April 10, 2013 I find that by using dynamic input I never miss the command line. Quote
Glen1980 Posted April 10, 2013 Posted April 10, 2013 I do use dynamic input, but I cast a quick glance down to the command line to check the prompt, just to make sure I've started the right command. e.g I've set up ctrl & shift d to start the break at point Macro and ctrl D to start layer isolate as a macro turning off the other layers (ctrl F for fade.) Even though I've had these set up for over a year I still occasionally confuse them. Quote
guran Posted April 10, 2013 Posted April 10, 2013 I try not to use the ctrl-, shift- and alt-keys to start command, only alias from acad.pgp and lisproutines. Quote
