hi I'm using AutoCAD architecture 2012 my problem is that i imported a AutoCAD Lt drawing unit is mm and when i try to draw walls and stuff the walls are so big what can i do to rescale my drawing and getting it bigger to feet plz help
I'm feeling :cry:
Edited by SLW210
You are doing your drawing in imperial units (feet and inches) but imported(?) a drawing that was done in millimeters?
Can't you simply scale it to correct size?
Or just use -DWGUNITS and set as desired.
And how about watching the language, I edited your post.
I saw where you use Architecture not AutoCAD as shown in your profile. -UNITS may work with Architecture.
