Hello,I once found a Lisp make a dynamic block to a static block. Running well so far. But now I have found a way that all lines in the block included. Characterized the block unnecessarily large and blows to the drawing.Unfortunately I do not remember where I got the Lisp and ask to talk because if you could change that?Thank you
(defun c:UnDynamic
       _get_item
       _right
       _make_key
       _dynamic->static_block
       _get_locked
       _get_dynamic_inserts
       _main
   (defun _get_item ( collection key / item )
       (vl-catch-all-apply
         '(lambda ( ) (setq item (vla-item collection key)))
       item
   (defun _right ( str n / len )
       (if (< n (setq len (strlen str)))
           (substr str (1+ (- len n)))
           str
   (defun _make_key ( collection prefix len / key )
       (  (lambda ( i pad )
               (while
                   (_get_item collection
                       (setq key
                           (strcat prefix
                               (_right
                                   (strcat pad (itoa (setq i (1+ i))))
                                   len
               key
           0
           (  (lambda ( pad )
                   (while (< (strlen pad) len)
                       (setq pad (strcat "0" pad))
                   pad
   (defun _dynamic->static_block ( blocks insert len )
       (vla-ConvertToStaticBlock
           insert
           (_make_key blocks "STATIC_" len)
   (defun _get_locked ( layers / locked )
       (vlax-for layer layers
           (if (eq :vlax-true (vla-get-lock layer))
               (setq locked (cons layer locked))
       locked
   (defun _get_dynamic_inserts ( blocks / inserts )
       (vlax-for block blocks
           (vlax-for object block
               (if (eq "AcDbBlockReference" (vla-get-objectname object))
                   (if (eq :vlax-true (vla-get-isdynamicblock object))
                       (setq inserts (cons object inserts))
       inserts
   (defun _main ( document / blocks inserts locked len )
       (if
           (setq inserts
               (_get_dynamic_inserts
                   (setq blocks (vla-get-blocks document))
               (foreach layer (setq locked (_get_locked (vla-get-layers document)))
                   (vla-put-lock layer :vlax-false)
               (setq len (strlen (itoa (length inserts))))
               (foreach insert inserts
                   (_dynamic->static_block blocks insert len)
               (foreach layer locked
                   (vla-put-lock layer :vlax-true)
   (_main (vla-get-activedocument (vlax-get-acad-object)))
  • 3 years later...
