Reu Posted March 18, 2013 Share Posted March 18, 2013 Help anyone? http://www.theswamp.org/index.php?topic=44203.0 Thanks, Reuben Shilling Quote Link to comment Share on other sites More sharing options...
Reu Posted March 18, 2013 Author Share Posted March 18, 2013 Solved. http://www.theswamp.org/index.php?topic=44203.new#new Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 19, 2013 Share Posted March 19, 2013 Another solution you can edit a blocks attributes by its creation position and ignore all together the attribute tag method of changing. I started with this method in VBA Attrib(x) where x is the order number, I now have a VL version nice thing here is you can change any or all with control. (vl-load-com) (setq y 1) (setq ss1 (car (entsel))) (setq bname (vla-get-name(vlax-ename->vla-object SS1))) (setq x (getint "\nEnter line no to pick")) ; change this line in block (SETQ newstrblank ".") (foreach att (vlax-invoke (vlax-ename->vla-object SS1) 'getattributes) (if (= y x) (vla-put-textstring att newstrblank) ) ) (setq y (+ Y 1)) ) Quote Link to comment Share on other sites More sharing options...
