Hello
Im looking for some LIPS wchich help me makre make drawing descriptions.
For example : in may drawing a have few blocks and I want to copy theirs parameters to descriptions block
How to copy attributes between blocks
Edited by ineedineed
The source block [blue Color]
The target block [Attribute block]
Now, where did the value "843W" comes from? The source block is also an attribute block?
Pretty easy to do if you search here for "update attributes" or visit lee-mac.com also under BIGAL try "Issued for construction" look for editing block attributes.
You use a blocks tag name to GET a value then use PUT to change other blocks attribute value, your only problem is that a simple code will work with only two blocks, but there is another way you can also get & put a blocks attributes by their creation order so you could write a pick block 1 pick block 2 attribute position 3 = attribute position 2 note this is not there visual appearance.
I want copy 3d measurements of this blue block to my description block ex height/ width/ length
form me coding lips for my own is too hard case,
