I was wondering if there is a quick and easy way to fix shaky lines in a drawing? I had to draw with angles that make the lines look terrible.
Just didn't know if there was a shortcut command I could use to make them look better?
Otherwise I will have to redraw. Thank you!
Angled lines will appear to have a case of the jaggies. I wouldn't be too concerned with it. There is no need to redraw any of your geometry.
Thanks for the reassurance :) When I plot to a PDF the lines really don't look too bad! When drawings angles for buildings sometimes it's just not right...
When the lines begin plotting as bad or worse than they appear on your screen that's the time to start worrying.
check what DPI you are plotting to PDF in? Low res PDF will look pixely
  • 3 months later...
A Viewres setting of 5000 is more than sufficient in most cases.
