stutz00 Posted March 13, 2013 Posted March 13, 2013 I have a 4' light fixture that is a rectangle. Right now I have it set up to where I can stretch it and it copies it’s self whatever length that I stretch it in increments of 4'. Is there a way for me to modify this so that when I stretch it along an arc, that it copies its self and rotates its self along the edge of the arc? Thank you, John C. Kimmel Quote
jrn Posted March 14, 2013 Posted March 14, 2013 If I understand your question, and assume that your drawing in 2D, I would suggest trying the ARRAY command. Depending on what you want the result to be, choose array along path or polar array. The dynamics of you block will function again, if you Xplode your array Quote
