Polyface Mesh to Topographic Map
Hello there,
I have some topography I've converted from SketchUp to .Dwg and I was curious if AutoCad (or any of it's versions) had the capabilities of turning this series of meshes into a run-of-the-mill topographic map. For instance, a standard plan view showing elevation lines at say 2' intervals.
If any of the versions are capable I can definitely get the 30 Day trial and give it a go.
Many many thanks in advance and I hope you all have a nice evening!
Best regards,
Rich
That is not a feature of generic AutoCAD. You might have to look at Civil 3D but I am not 100% sure what its capabilities are.
One other possible option here....http://www.glamsen.se/CadTools.htm
