Can someone help me on why this code is throwing nil?
(command "_area")
 (while (> (getvar "cmdactive") 0) (command pause))
 (setq e (getvar "_area"))
e has nil value...
Try:
(command "_.area")
(setq e (getvar "area"))
I don't believe that getvar honors the "_"
Try :
(getvar "AREA")
-David
(Nop Nop)
Neither has worked !
(getvar "AREA") has worked.
Since when area should be written in capitals ???? :?
ok, now why this is giving a "bad function"?
 (if (= fuel "a") ((setq kw (getreal))
		(setq p (* 6 kw))
		(setq a (* 0.25 k)))
  		      ((setq p (* 0.5 e))
You have certainly done something wrong.
(if (= fuel "a")
       (setq kw (getreal))
       (setq p (* 6 kw))
       (setq a (* 0.25 k))
       (setq p (* 0.5 e))
       (setq a (* 0.25 k))
(if (= fuel "a")
  (setq kw (getreal "\nHow many Km?")
 p  (* 6 kw)
 a  (* 0.25 k)
  );; setq
 p  (* 0.5 e)
 a  (* 0.25 k)
  );; setq
  );; if
;;or
(if (= fuel "a")
 (setq kw (getreal "\nHow many Km?"))
 (setq p (* 6 kw))
 (setq a (* 0.25 k))
);; progn
   (setq p (* 0.5 e))
   (setq a (* 0.25 k))
 );; progn
);; if
           (setq p (* 6 kw))
                ((setq p (* 0.5 e))
Use progn
(if (= fuel "a")
   (setq kw (getreal))
   (setq p (* 6 kw))
   (setq a (* 0.25 k))
   (setq p (* 0.5 e))
   (setq a (* 0.25 k))
Or combine the grouped setqs
(if (= fuel "a")
 (setq kw (getreal)          p (* 6 kw)          a (* 0.25 k)  )
 (setq p (* 0.5 e)          a (* 0.25 k) )
