nyaromulo Posted October 31, 2008 Posted October 31, 2008 Hello Could you please help me export AECC points from Civil 3D 2008 drawing to txt? thank you Quote
nyaromulo Posted November 3, 2008 Posted November 3, 2008 Hello, I have tryed to export points using the link you have given me. However I am suppose to have a DEM surface, base on the process, which I currently do not have. I only have AECC points within the Civil 3D drawing that is all i have for now. Is there another way to export points without going through the DEM surface, since i do not have DEM surface at the moment? Quote
lpseifert Posted November 3, 2008 Posted November 3, 2008 Did you try Points > Import/Export Points > Export Points ? Quote
nyaromulo Posted November 3, 2008 Posted November 3, 2008 Yes I did, and error comes says, "No points were transferred from the source" by the way I used the format of PENZD (space delimited). Quote
rustysilo Posted November 3, 2008 Posted November 3, 2008 No you don't use the dem or surface to export. Just right-click Points in toolspace > prospector tab... etc. With the error you got I would almost think that you do not have any points in the dwg. Are you sure your points are Civil 3d points and not AutoCAD points, Land Desktop points, Softdesk points, etc.? Quote
lpseifert Posted November 3, 2008 Posted November 3, 2008 Maybe the points were created using LDD, and you opened the dwg with C3D. Try Points > Utilities > Convert Land Desktop Points. Then try to export. Quote
nyaromulo Posted November 3, 2008 Posted November 3, 2008 Hello Just as you said...that is what i did and it all worked super well. thanks so much! Quote
FTC Posted July 27, 2009 Posted July 27, 2009 Greetings, I’m using LDD 2009 (with the latest patches installed). After we switch to 2009 from 2007, we have been experience new problems that we are straggling and we can not solve, perhaps somebody can help us. When we try to manipulate the point’s display properties (such as markers, on/off point’s number, elev & desc), after we select the display properties routine from the pull down menu: Command: Points to Modify (All/Numbers/Group/Selection/Dialog) ? : If we select “All” the program doesn’t respond anymore, sometimes after around 3 or 5 minutes comes back and it gave us the next screen, this routine didn’t take that long before in LDD 2007. Any idea will be really appreciate. Thanks Quote
rustysilo Posted July 28, 2009 Posted July 28, 2009 Shouldn't have that sort of trouble unless your computer(s) just isn't up to spec for '09. First compare your computer specs with the requirements for '09. Second maybe uninstall both, run a registry cleaner, then reinstall only '09? Quote
parttimeCAD Posted October 26, 2009 Posted October 26, 2009 Greetings all, I don't know if i'm just being thick or have not used AutoCAD as much and regually as the rest of you all but i have read this thread a few time and still can't do it. when i type in points in the command line i get an error. I am looking to export "points" symbolized as a node, with an easting, northern and elevation, into an XYZ file (csv or txt). I use to do this sort of thing regually as a surveyor but have forgotten how to do it, this was using 2004 eddition i now use 2007 version. I think it was a simple solution not a "lisp" file as never heard of one of them. Some times there is 10 sometimes there is 10 000!! in which case i use a DXF backcloth and set out that way but want to get more accuracy and have a "paper trail" for my setting out. All help much appreciated Quote
CarlB Posted October 26, 2009 Posted October 26, 2009 Are you using Civil 3D, LDD, or plain AutoCAD? If plain AutoCAD you'll probably need a lisp routine to do this. The particular routine may depend on what kind of point objects are in the drawing-AECC points, block with attributes, etc. What does the "list" command report for a point? Quote
parttimeCAD Posted October 26, 2009 Posted October 26, 2009 I'm using normal AutoCAD, the list command provides the below details. " Customization file loaded successfully. Customization Group: ACAD Customization file loaded successfully. Customization Group: CUSTOM Customization file loaded successfully. Customization Group: EXPRESS Opening an AutoCAD 2007 format file. Substituting [simplex.shx] for [ENGINEERING.shx]. Regenerating model. AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc. AutoCAD menu utilities loaded. Autodesk DWG. This file is a Trusted DWG last saved by an Autodesk application or Autodesk licensed application. Command: COMMANDLINE Command: Specify opposite corner: Command: list Select objects: 1 found Select objects: POINT Layer: "points" Space: Model space Handle = a0e at point, X=421412.6109 Y=576401.0973 Z= 121.0000" :unsure: The "point" are taken from using the "measure" command on a polly line to produce a node every set distance for setting out. cheers Quote
hernanvessuri Posted October 29, 2009 Posted October 29, 2009 Thanks Fuccaro... great your script... it works just perfect... Hernan Quote
rustysilo Posted December 3, 2009 Posted December 3, 2009 What do you need help with? parttimeCAD, did you get things worked out? Quote
mohd_arastu Posted December 4, 2009 Posted December 4, 2009 i want to know that how to import text with their coordinates from excel to auto-cad Thanks Quote
