I am getting a save error message when trying to save amendments on existing drawings; the message is;
First, an error message on the screen, stating; Error writing/closing file
then, trying to close the file, the message on the Command line states:
*Warning* Multiply owned object, handle "4B73"
I cannot save anything, which as I am sure you agree, is something of a problem.
Any ideas please?
Try this: *Warning* Multiply owned object, handle "D2209" Paste the line below on your command prompt, it will highlight the trouble-maker entity: (progn (command "_ZOOM" "_O" (setq x (handent "D2209")) "")(sssetfirst nil (ssadd x))(princ)) or (entget (handent "D2209"))
Sorry this link is not work.......
This is not a link. Yuo must paste this line to your command prompt: (progn (command "_ZOOM" "_O" (setq x (handent "D2209")) "")(sssetfirst nil (ssadd x))(princ))
Sorry, wrong handent. Here is the correct one (progn (command "_ZOOM" "_O" (setq x (handent "4B73")) "")(sssetfirst nil (ssadd x))(princ))
Have you tried doing an audit of the drawing file to find/fix errors?
mfahadrazzaq,
First, you should think about disabling the Comm Center (aka SpyCenter). See THIS
Are you saving to a network? If so try saving to the local drive.
Have you tried -PURGE?
Have you tried AUDIT?
Paste this to your commandline
(entdel(handent"4B73"))
guran,
Please read the CODE POSTING GUIDELINES and edit your posts to include Code Tags.
