Im trying to move radial dimension text away from the dimension line so I can add in text between the dimension and dimension line.
#1 is the default style
#2 is what happens when I do "Move text only", it moves the dimension line to inside the radial and I do not want that.
#3 is how it looks when I just manually edit the dimension text
#4 is how I want it to look
#4 is a combination of dimension and a manually added leader with the dimension line removed. How can I move the dimension text on a radial without the dimension line automatically moving to the inside? Or is there another way to add in text outside the box while having the dimension text offset from the line?
TEST.dwg
