Hello,
I have been pulling my hair out for the last few days (i'm almost bald now), and i have not been able to get this command correct. I have been reading forums and getting plenty of information on how to update attributes within blocks, but i can't seem to combine that with grabbing a Z value of the block (or attribute) to populate the Attribute field.
Any assistance would be greatly appreciated. I have not tried to create anything more than simple LISP routines, so please assume i know nothing in your responses.
Thanks
(defun c:sdh2 (/ blks i sn n e)
;;; The Loop i'm using, not sure if it works
(if (setq blks (ssget '((0 . "INSERT") (66 . 1))))
(repeat (setq i (sslength blks))
(setq sn (ssname blks (setq i (1- i))))
(setq n (entnext sn))
(while
(not
(eq (cdr (assoc 0 (setq e (entget n))))
"SEQEND"
(if (eq (cdr (assoc 0 e)) "ATTRIB")
;;; My Specific Attribute Name within the block
(cond ((eq (cdr (assoc 2 e)) "DH")
;;; May attempt to grab the Z Height
;;; returns error: bad argument type: consp 90.468
;;; 90.468 being the correct z height value i want on this particular block
(setq z (cdr(nth 3(assoc 10 e))))
(entmod (subst (cons 1 z) (assoc 1 e) e))
(setq n (entnext n))
I just had what alcoholics refer to as a "moment of clarity" and got it figured out. On the off chance someone else needs it, here it is below. i was not formatting my Z value correctly. it now is formatted as (1 . "ZHEIGHT") which is what the attribute required.
(defun c:sdh (/ blks i sn n e)
;;; Set Default Height on all Cap Blocks
(while
(not
"SEQEND"
(setq z (cdr(assoc 10 e)))
(setq z (caddr z))
(setq z (rtos z 2 6))
