jag2999 Posted March 2, 2013 Share Posted March 2, 2013 Hello, I have been pulling my hair out for the last few days (i'm almost bald now), and i have not been able to get this command correct. I have been reading forums and getting plenty of information on how to update attributes within blocks, but i can't seem to combine that with grabbing a Z value of the block (or attribute) to populate the Attribute field. Any assistance would be greatly appreciated. I have not tried to create anything more than simple LISP routines, so please assume i know nothing in your responses. Thanks (defun c:sdh2 (/ blks i sn n e) ;;; The Loop i'm using, not sure if it works (if (setq blks (ssget '((0 . "INSERT") (66 . 1)))) (repeat (setq i (sslength blks)) (setq sn (ssname blks (setq i (1- i)))) (setq n (entnext sn)) (while (not (eq (cdr (assoc 0 (setq e (entget n)))) "SEQEND" ) ) (if (eq (cdr (assoc 0 e)) "ATTRIB") ;;; My Specific Attribute Name within the block (cond ((eq (cdr (assoc 2 e)) "DH") ;;; May attempt to grab the Z Height ;;; returns error: bad argument type: consp 90.468 ;;; 90.468 being the correct z height value i want on this particular block (setq z (cdr(nth 3(assoc 10 e)))) (entmod (subst (cons 1 z) (assoc 1 e) e)) ) ) ) (setq n (entnext n)) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
jag2999 Posted March 2, 2013 Author Share Posted March 2, 2013 I just had what alcoholics refer to as a "moment of clarity" and got it figured out. On the off chance someone else needs it, here it is below. i was not formatting my Z value correctly. it now is formatted as (1 . "ZHEIGHT") which is what the attribute required. (defun c:sdh (/ blks i sn n e) ;;; Set Default Height on all Cap Blocks (if (setq blks (ssget '((0 . "INSERT") (66 . 1)))) (repeat (setq i (sslength blks)) (setq sn (ssname blks (setq i (1- i)))) (setq n (entnext sn)) (while (not (eq (cdr (assoc 0 (setq e (entget n)))) "SEQEND" ) ) (if (eq (cdr (assoc 0 e)) "ATTRIB") (cond ((eq (cdr (assoc 2 e)) "DH") (setq z (cdr(assoc 10 e))) (setq z (caddr z)) (setq z (rtos z 2 6)) (entmod (subst (cons 1 z) (assoc 1 e) e)) ) ) ) (setq n (entnext n)) ) ) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
