lizazelle Posted March 1, 2013 Share Posted March 1, 2013 I am trying to make a stylized model of a molecule and having some issues. Here's the sketch of what I'm trying to create: So far, I've been able to sweep a circle around a hexagon-shaped path, which will create the single-bonds in the benzene ring in the finished product: I made a circle on the XY plane, then made a hexagon-shaped path on the YZ plane, did a coincident contraint on the center of the circle and attached it to the path and then did a sweep along the hexagon path. Hooray. Then I needed to create the covalent / double-bars on every other section. I figured I would create another hexagon-swept ring, but with all double-bars, and then cut and copy the bits of each together afterwards so it would look like this: I tried sweeping to faces, but it only gave me one segment, but it didn't work. So then I thought I'd sweep two circles around the edges of a square-faced sweep in hexagon form to end up with two rows, like in this example: So here's my attempt, but I can't get the edge of the square in the middle of the two guide circles to coincident-constrain to the corner point of the hexagon path (I tried "project geometry" to no avail, and it's turned on automatically): Here's the sketch of the face I'm trying to sweep: Not sure why it's not working this time around, and I might be going about this the wrong way... would love some help on this. Thanks! Quote Link to comment Share on other sites More sharing options...
lizazelle Posted March 1, 2013 Author Share Posted March 1, 2013 benzeneframe-2.ipt Here are the files I'm working with, in Inventor 2013... covalent-sweep-attempt.ipt Quote Link to comment Share on other sites More sharing options...
