JD Mather Posted April 18, 2013 Posted April 18, 2013 That is a beautiful rendering - almost looks like a picture. What software did you use for the rendering? Quote
togores Posted April 18, 2013 Posted April 18, 2013 You should specify you are using the Mac version, as no customization that uses ActiveX will work in that one... Quote
Lentezza Posted April 19, 2013 Author Posted April 19, 2013 That is a beautiful rendering - almost looks like a picture. What software did you use for the rendering? Thank you - it is Samsung Omnia 2......... Quote
Lentezza Posted April 19, 2013 Author Posted April 19, 2013 You should specify you are using the Mac version, as no customization that uses ActiveX will work in that one... Yeah, I could probably make my signature a bit bigger... La verdad es, que podría apprender mucho de lo que respondiste a mis preguntas y por eso querria agradecerte lo otra vez! Quote
togores Posted April 19, 2013 Posted April 19, 2013 Lo siento, a veces las prisas hacen que miremos pero no veamos... I posted a class to AU2012 Virtual which deals with 3D MESH objects and I took care in presenting only that which would work on Mac. Although I don't own a Mac:(. Maybe you could take a look at it and tell me if it really does work in Mac. The URL is: http://au.autodesk.com/?nd=class&session_id=10671 Also in Spanish: http://au.autodesk.com/?nd=class&session_id=10672 Quote
GP_ Posted April 19, 2013 Posted April 19, 2013 Thank you - it is Samsung Omnia 2......... A picture taken with a cell phone?!? Quote
Lentezza Posted April 19, 2013 Author Posted April 19, 2013 A picture taken with a cell phone?!? Er, yes. As I mentioned in the beginning, I WAS in the process of drawing this thing which later on I produced from solid wood..... Quote
