LISP2LEARN Posted February 27, 2013 Posted February 27, 2013 Hello guys, Code works just fine but I'm just curious on how would you approach this with "while" function. I need to explode all blocks in a drawing including nested one. Statement would be.. as long as there are blocks in the drawing continue to explode them. I use repeat 10 times to make sure everything was exploded. Thanks. (vl-load-com) (defun C:test (/ AB) (setvar 'qaflags 1) (repeat 10 (setq AB (ssget "_X" '((0 . "INSERT")))) (vl-cmdf "_.explode" AB "")) (setvar 'qaflags 0)) Quote
MSasu Posted February 27, 2013 Posted February 27, 2013 You should cycle as long as the selection by SSGET return something: (while (setq AB (ssget "_X" '((0 . "INSERT")))) (vl-cmdf "_.explode" AB "") ) Quote
LISP2LEARN Posted February 27, 2013 Author Posted February 27, 2013 MSasu, Tried your code and my autocad hangs up. MSasu said: You should cycle as long as the selection by SSGET return something: (while (setq AB (ssget "_X" '((0 . "INSERT")))) (vl-cmdf "_.explode" AB "") ) Quote
MSasu Posted February 27, 2013 Posted February 27, 2013 I cannot test it into AutoCAD 2009, but worked well for me in 2010 and 2013. Maybe try to explode the blocks one at a time: (while (setq AB (ssget "_X" '((0 . "INSERT")))) (repeat (setq index (sslength AB)) (command "_EXPLODE" (ssname AB (setq index (1- index)))) ) ) Sorry for delay, for a while there was a constant error while trying to access the CADTutor... Quote
Lee Mac Posted February 27, 2013 Posted February 27, 2013 This isn't great, but should perform as required: (defun c:explodeall ( / explode layouts ) (setq layouts (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) explode t ) (while explode (setq explode nil) (vlax-for layout layouts (vlax-for obj (vla-get-block layout) (and (= "AcDbBlockReference" (vla-get-objectname obj)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-explode (list obj)))) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-delete (list obj)))) (setq explode t) ) ) ) ) (princ) ) (vl-load-com) (princ) Quote
LISP2LEARN Posted February 27, 2013 Author Posted February 27, 2013 I'm the one who suppose to be apologizing, fell asleep on you. Sorry. MSasu said: Sorry for delay, for a while there was a constant error while trying to access the CADTutor... Quote
LISP2LEARN Posted February 27, 2013 Author Posted February 27, 2013 Thanks again Lee. Works wonderful. You rewrite everything and now I'm lost again. Another lisp to dissect on. One more thing. How do i incorporate this with your code. Not familiar with visual lisp yet. I want to delete certain blocks on certain layers and omit block with certain names. This is my selection set. (ssget "_X" '((0 . "INSERT") (8 . "0,A-WALL,A-WINDOWS,A-DOOR") (-4 . "<NOT") (2 . "A-MILLWORK,A-DESK,A-CHAIR,A-TABLE,F-*") (-4 . "NOT>"))) Lee Mac said: This isn't great, but should perform as required: (defun c:explodeall ( / explode layouts ) (setq layouts (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) explode t ) (while explode (setq explode nil) (vlax-for layout layouts (vlax-for obj (vla-get-block layout) (and (= "AcDbBlockReference" (vla-get-objectname obj)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-explode (list obj)))) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-delete (list obj)))) (setq explode t) ) ) ) ) (princ) ) (vl-load-com) (princ) Quote
Lee Mac Posted February 27, 2013 Posted February 27, 2013 LISP2LEARN said: Thanks again Lee. Works wonderful. You rewrite everything and now I'm lost again. Another lisp to dissect on. You're welcome, feel free to ask if you have any questions about the code. LISP2LEARN said: One more thing. How do i incorporate this with your code. Not familiar with visual lisp yet. I want to delete certain blocks on certain layers and omit block with certain names. This is my selection set. (ssget "_X" '((0 . "INSERT") (8 . "0,A-WALL,A-WINDOWS,A-DOOR") (-4 . "<NOT") (2 . "A-MILLWORK,A-DESK,A-CHAIR,A-TABLE,F-*") (-4 . "NOT>"))) The following modifications should suffice: (defun c:explodeall ( / explode layouts name ) (setq layouts (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) explode t ) (while explode (setq explode nil) (vlax-for layout layouts (vlax-for obj (vla-get-block layout) (and (= "AcDbBlockReference" (vla-get-objectname obj)) [color=red](wcmatch (strcase (vla-get-layer obj)) "0,A-WALL,A-WINDOWS,A-DOOR") (or (and (vlax-property-available-p obj 'effectivename) (setq name (strcase (vla-get-effectivename obj))) ) (setq name (strcase (vla-get-name obj))) ) (not (wcmatch name "A-MILLWORK,A-DESK,A-CHAIR,A-TABLE,F-*"))[/color] (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-explode (list obj)))) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-delete (list obj)))) (setq explode t) ) ) ) ) (princ) ) (vl-load-com) (princ) Untested code, but should perform as required. Quote
LISP2LEARN Posted February 27, 2013 Author Posted February 27, 2013 Thanks Lee. Perfect. Understand it all now, every bit of it. Except for one thing. (setq layouts (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) [color="red"]explode t[/color]) Why did you assign variable "explode" before the while function? Tried to remove it and code didn't work. Reason behind it? Lee Mac said: You're welcome, feel free to ask if you have any questions about the code. Quote
Lee Mac Posted February 27, 2013 Posted February 27, 2013 LISP2LEARN said: Thanks Lee. Perfect. Excellent. LISP2LEARN said: Understand it all now, every bit of it. Except for one thing. (setq layouts (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))) [color=red]explode t[/color]) Why did you assign variable "explode" before the while function? Tried to remove it and code didn't work. Reason behind it? Hint: the value of the explode variable is the test expression for the while loop. Quote
LISP2LEARN Posted February 28, 2013 Author Posted February 28, 2013 got it. knew I was over thinking that one. if there is no explode "while" will exit automatically. learned something. thanks again for your help lee. Quote
Lee Mac Posted February 28, 2013 Posted February 28, 2013 LISP2LEARN said: got it. knew I was over thinking that one. if there is no explode "while" will exit automatically. learned something. thanks again for your help lee. Exactly: since the explode symbol is declared local to the function it has a null value when the program is evaluated until assigned a non-nil value. The explode variable is then reset to nil for each iteration of the while loop to ensure the loop ceases when no more blocks can be exploded. Quote
