afrazawan Posted February 26, 2013 Posted February 26, 2013 i'm trying since last day to install civil 3D in my system but problem is that when installation is running error message is showing you have already install civil 3D in you system i check add and remove option there is no any CIVIL 3D even i also removed 2012 CAD so pleas help how can i install Quote
Organic Posted February 26, 2013 Posted February 26, 2013 Look in C:\\Program Files\Autodesk (or similar) and see if you see the Civil 3D folder in there. Quote
edwinprakoso Posted February 26, 2013 Posted February 26, 2013 That's because you installed it before. When doing uninstall, the installation registry still remains. Windows thinks you still have the software, which you don't. Try to use Microsoft FixIt (doesn't work for Windows 8 ) here: support.microsoft.com/fixit/ Quote
afrazawan Posted February 26, 2013 Author Posted February 26, 2013 Look in C:\\Program Files\Autodesk (or similar) and see if you see the Civil 3D folder in there. i already check this dir Quote
SLW210 Posted February 26, 2013 Posted February 26, 2013 Looks like you are trying to install an Object Enabler not Civil 3D. Quote
afrazawan Posted February 27, 2013 Author Posted February 27, 2013 i want to uninstall my dear what ever is this in image give me solution Quote
SLW210 Posted February 27, 2013 Posted February 27, 2013 (edited) Resolving installation issues with a clean install of AutoCAD Civil 3D Edited June 4, 2018 by SLW210 Update Link Quote
PotGuy Posted February 28, 2013 Posted February 28, 2013 Wouldn't this be under the Software section? Quote
afrazawan Posted February 28, 2013 Author Posted February 28, 2013 thanks for al of my friends spicially SLW210 problem resolved Quote
shayan_z01 Posted May 25, 2018 Posted May 25, 2018 (edited) Resolving installation issues with a clean install of AutoCAD Civil 3D it doesn't come up anything . it forward me to autodesk.com Edited June 4, 2018 by SLW210 Update Link Quote
SLW210 Posted June 4, 2018 Posted June 4, 2018 You do not show that you use Civil 3D, but I updated the links for now. Autodesk has updated their web page a few times since the old one. Plain AutoCAD may be different. Quote
