lasan Posted February 24, 2013 Share Posted February 24, 2013 Hi, It's my first post in this forum, I hope this is the right place to post my question. Im using Autocad Map 2011 and I have a DWG file with hundreds of data tables (2x2) spread all over a map. All table content is in text, and they have a cell with an ID (manually inserted in autocad - in the first top/left cell) My goal is to link the data table contents to an excel spreadsheet, so that i can update table values from excel. Can someone help me? Attached its a dwg file to get the idea. Drawing1.dwg Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted February 25, 2013 Share Posted February 25, 2013 I am not 100% sure the difference from regular ACAD to Map, but from what I can see on normal ACAD you would have to set up an individual data link for each table you have inserted (easiest way would be through a named range in you Excel file). Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 25, 2013 Share Posted February 25, 2013 With hundreds of data tables spread over the drawing that is going to be a pain in the neck unfortunately. Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted February 25, 2013 Share Posted February 25, 2013 That is the only way I can think of OOB, there are likely LISP routines/addins that will allow this to be done more efficiently. This may be a solution and Blocks could be used rather than table. I have not used this product myslef, but I have been wanting to take a look at it for some time now. Quote Link to comment Share on other sites More sharing options...
lasan Posted February 27, 2013 Author Share Posted February 27, 2013 Sorry for late reply. Thanks for the suggestions. Mike_Taylor, thats exacly what im trying to avoid, to link individually each data table. But Im going to try your suggestion, on the second post. I will give feedback. Im not sure if this makes sense, but here it goes... If I had the information in excel and the only think i need from cad data tables was the coordinates to use as a key to table id (content from first cell) would it be easier to solve? Quote Link to comment Share on other sites More sharing options...
Emigrato Posted February 27, 2013 Share Posted February 27, 2013 You can link N Excel records (each containing M fields) to N Autocad ID's, but the result won't be a beautiful table like yours. With the command _MAPDEFINELT, you'll get N objects, each containing M "object datas", visible in Properties. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 28, 2013 Share Posted February 28, 2013 Rather than having real time data links you could run a lisp that read the excel and updated the tables like wise add a table - add to excel. It only requires the table ID to be part of excel data. Quote Link to comment Share on other sites More sharing options...
