xrunnurx23 Posted February 20, 2013 Posted February 20, 2013 I have created a custom linetype using a shape & also added text. I have tried countless combinations to have a different spacing for the text, without affecting the frequency of the shape. I want there to be no space between the shape, just repeating. But I want the text to display only once for every 4 times the shape repeats. Is this at all possible? Every time I change the text spacing, I get huge gaps in the between the shape and it seems that their spacing cannot be independently controlled. Please help! Thanks! Quote
ReMark Posted February 20, 2013 Posted February 20, 2013 Post an image of what you are trying to achieve. Quote
xrunnurx23 Posted February 20, 2013 Author Posted February 20, 2013 Basically I am trying to achieve the shape appearing like the first line and the text to appear like the second line. I am having trouble achieving both in 1 linetype. Quote
ReMark Posted February 20, 2013 Posted February 20, 2013 Is this what you are hoping to achieve? Quote
xrunnurx23 Posted February 20, 2013 Author Posted February 20, 2013 No, I would like the shape to reoccur 4x for every one time that the text appears. Also, I do not want a space in between the shape, I want the long dash to start and end with no gap, hence making the long dash twice as long as the original shape. From the picture I sent, I would like the line to look exactly like it does in the top case, but the text to appear less frequently. I want a different spacing for the shape than I do for the text within the same line. Sorry if that is confusing. Quote
eldon Posted February 20, 2013 Posted February 20, 2013 Perhaps you could set up two linetypes, one with the shape and one with the text, and combine them using a Multiline Quote
xrunnurx23 Posted February 20, 2013 Author Posted February 20, 2013 Seems a bit redundant I think.... I was hoping to just use 1 linetype to achieve both. Quote
eldon Posted February 20, 2013 Posted February 20, 2013 I can only wish you the best of luck with your endeavours. Keep us posted if you succeed. If you posted the linetype definition that you have so far achieved, then someone might spot the way forward. Quote
welldriller Posted February 27, 2013 Posted February 27, 2013 [ATTACH]40518[/ATTACH] Is this wha you wanted ? Quote
