bgbylund Posted February 13, 2013 Posted February 13, 2013 CAD 2010 ...how do I import a .ctb file that I have just created in plot style manager...into my plot style table? thanks Quote
MSasu Posted February 13, 2013 Posted February 13, 2013 The CTB styles are in fact files stored into UserProfile\Plot Styles folder; the same folder that open when you call STYLEMANAGER command. After created, it should be available when call the PLOT command (in top-right pop-up list). Try to do a search on your hard-disk to see if was saved correctly and move it where should reside if case. Quote
bgbylund Posted February 13, 2013 Author Posted February 13, 2013 Hi thank you very much...I figured it out with your help...very appreciative of your clear way of explaining..My plot style table was only reading/displaying .stb files, was able to get it to read/display .ctb files with the convertpstyles command when opened on my layout. Thanks! Quote
